no 4wd vsc lights on
kartracer8
Hello all, Hopefully I can get an answer here with my problem. I have a 2005 V8 4wd. Just recently my VSC trac, trac off, ABS and brake lights are on??? I tried pulling codes and there are none. I also have no 4Wd. the front wheels are no locking so only the rears are driving the car. I tried a new Brake light Switch already with no chance in the the problem. Any ideas? Thank you in advance.
The ABS light usually means you have a code for the system and that will turn on VSC & Trac lights, didn't think that would put on the brake light though. A standard code reader will not pull ABS codes. When mine came on it was because of a failing wheel speed sensor.
Problem fixed. After thinking about it and not having any 4AWD and feeling like the rear brake were only working. I went checking on the ABS circuits and found that the 30 fuse under the hood was loose and all the lights went out and everything works now.
AndiGarage
