MeefZah
Oh, I meant two kayaks SIDE BY SIDE without extra accessories on factory cross-bars...![]()
Just to clarify I was referring to one kayak on the factory crossbars, not on the basket.
The only use I have for the stock roof rack with out cross rails is when I wash or wax the 4runner. It makes it easy to wash or wax the roof by standing on the running board and grabbing the roof rail to pull be up to the roof. The only other use I have for them is that when I am using my magnetic mount cb antenna I tie wrap the cb antenna cable to the roof rack to keep the cable from damaging the paint.
there is metal inside the end piece on the factory bars
However I strongly recommend the LFD off-road crossbars though over factory, they are much stronger, sit a little bit higher, offer a flat surface, and allow you to easily bolt on whatever you want.
i have the hi-lift mount that is being developed on mine, there are a few other accesories that will be available in the next month or so
http://apexoverland.com/#!/LFD-Off-Road-Ruggedized-Cross-Bar-Sets/p/97509282/category=21774015
I saw these on Instagram. How do they do with wind noise?
installed/un-installed the same way as the factory cross bars
you pop off the cap in the back, if you have a paint can opener that is the easiest tool to use. then you just slide them in and tighten the bolts.
there are 1.25" x .25" squares that go into the side rails, 2 on each side of each cross bar (4 total per cross bar) that the bolts go into.
All you need is something to pop off the back cover (screw driver, plastic panel tool, paint can opener, etc...) and a socket or wrench. The rails have pre-drilled 3/8" holes to mount accessories and also larger holes that fit maxtrax mounting pins. The hi-lift mount works well, and since it's just holes and a flat metal surface you can pretty much mount or drill and mount whatever you need.
I'm Jacob with LFD Off Road. [MENTION=113833]e60ral[/MENTION] has been running one of our prototype sets helping us evaluate them. We just released the first version production units, and the first sets are actually shipping tomorrow.
The Crossbars are now using T nuts to secure to the rails instead of the squares we used in the prototypes. Still need to pop off the rear covers to slide them in, but they come off pretty easy. We're also looking at ways to make future versions install without removing the rear caps.
Let me know if there's any other questions, and check us out on facebook, https://www.facebook.com/LFDOffRoad/. We're still working on getting our webpage up.
Jacob, any chance you guys have tested these with an RTT?
Here in 2 weeks, I am looking at getting a set of these and mounting a Roam Adventure Company Vagabond V2 (+ annex) to my 4Runner. I will probably go with a set of 3 just to be certain there is some weight distribution.
I am very confident that this setup will both work well and be the closest I can get to the 4Runner to keep as low a profile and center of gravity as possible. I was just curious if you guys had already tried it.
Cheers!
As far as I know, no one's put a RTT on them yet. It should work fine, if not we'll either take them back or work with you on making modifications so they do work![]()
We've talked about making a QD tent mount, but haven't gotten to looking at that yet. Been busy working on the other things...
VERY NICE!!!
I will let you guys know once I can order them from @apexoverland and let you know how the process goes.
One other question, from pictures it looks like these sit just above the height of the OEM rail feet (or the covers of them to be exact). Is that correct? If so, these would actually be perfect for a RTT setup...
This product looks great, really looking forward to the QD RTT option.
Can you share some close-up photos of how these connect to the factory rails? Also, knowing the height over the factory bars would be nice as well as how many holes are drilled into the rails.
