Is there any function to a roof rack without cross bars?
Factory Cross Bars
When you have cross bars and want to load boxes of gear or firewood on top for camping, you have to put it directly on the metal roof and then tie it down to the side and cross rails. If you go of road with that gear on top it will eventually work loose and slide around. That scratches your roof. I've done it and it isn't pretty.
That's why I replaced the side rails with a Baja Rack Utility Flat Rack soon after I bought the car. Now I load firewood, propane fuel cans, shovels and boxes of gear on the Baja Rack and tie it down from any of the many cross rails (not mesh).
I've had lumber and plywood up there many times with no trouble.
Roof rack
The only use I have for the stock roof rack with out cross rails is when I wash or wax the 4runner. It makes it easy to wash or wax the roof by standing on the running board and grabbing the roof rail to pull be up to the roof. The only other use I have for them is that when I am using my magnetic mount cb antenna I tie wrap the cb antenna cable to the roof rack to keep the cable from damaging the paint.
Washing the roof is much easier without the rails... Did the "roof rack delete" about two years ago. Like the cleaner look, and washing-waxing is much easier.
Here ya go...
Factory roof rails
I went up to Idyllwild, CA last weekend with my chainsaw to work on clearing dead and dying trees around a friends cabin. The saw was in a box that contained the mess but I did not want a can of gas inside the car. It smells bad and is a hazard in case of an accident. I put the gas and chain oil in a crate and tied the crate down to my Baja Rack, Flat Utility Rack (no mesh) using the side and cross rails. It was super easy. If I had the factory rails the crate would have been sitting directly on the metal roof.
Same goes for firewood, which is bulky and often dirty so you don't want it inside the vehicle. The shovel you should be carrying for any off-roading goes up there too.
there is metal inside the end piece on the factory bars
However I strongly recommend the LFD off-road crossbars though over factory, they are much stronger, sit a little bit higher, offer a flat surface, and allow you to easily bolt on whatever you want.
i have the hi-lift mount that is being developed on mine, there are a few other accesories that will be available in the next month or so
http://apexoverland.com/#!/LFD-Off-Road-Ruggedized-Cross-Bar-Sets/p/97509282/category=21774015
I saw these on Instagram. How do they do with wind noise?
i don't notice any additional wind noise from the bars, but obviously when you start mounting stuff to them it will just depend on what you put up there
(disclaimer: I'm running KO2 tires, although they are generally regarded as being pretty quiet for an AT tire)
With the hi-lift on top there is a slight increase in wind noise, but not nearly to the point where it is distracting or annoying
some might also be interested in knowing that i have been through numerous car washes with no issues, so these appear to be carwash safe (at least with nothing mounted)
I'm Jacob with LFD Off Road. [MENTION=113833]e60ral[/MENTION] has been running one of our prototype sets helping us evaluate them. We just released the first version production units, and the first sets are actually shipping tomorrow.
The Crossbars are now using T nuts to secure to the rails instead of the squares we used in the prototypes. Still need to pop off the rear covers to slide them in, but they come off pretty easy. We're also looking at ways to make future versions install without removing the rear caps.
Let me know if there's any other questions, and check us out on facebook, https://www.facebook.com/LFDOffRoad/. We're still working on getting our webpage up.
installed/un-installed the same way as the factory cross bars
you pop off the cap in the back, if you have a paint can opener that is the easiest tool to use. then you just slide them in and tighten the bolts.
there are 1.25" x .25" squares that go into the side rails, 2 on each side of each cross bar (4 total per cross bar) that the bolts go into.
All you need is something to pop off the back cover (screw driver, plastic panel tool, paint can opener, etc...) and a socket or wrench. The rails have pre-drilled 3/8" holes to mount accessories and also larger holes that fit maxtrax mounting pins. The hi-lift mount works well, and since it's just holes and a flat metal surface you can pretty much mount or drill and mount whatever you need.
Jacob, any chance you guys have tested these with an RTT?
Here in 2 weeks, I am looking at getting a set of these and mounting a Roam Adventure Company Vagabond V2 (+ annex) to my 4Runner. I will probably go with a set of 3 just to be certain there is some weight distribution.
I am very confident that this setup will both work well and be the closest I can get to the 4Runner to keep as low a profile and center of gravity as possible. I was just curious if you guys had already tried it.
Cheers!
[MENTION=136636]jafrush[/MENTION] : also, have you guys looked into making or do you make an RTT quick release/mount option?
Cheers!
As far as I know, no one's put a RTT on them yet. It should work fine, if not we'll either take them back or work with you on making modifications so they do work ;)
We've talked about making a QD tent mount, but haven't gotten to looking at that yet. Been busy working on the other things...
VERY NICE!!!
I will let you guys know once I can order them from @apexoverland and let you know how the process goes.
One other question, from pictures it looks like these sit just above the height of the OEM rail feet (or the covers of them to be exact). Is that correct? If so, these would actually be perfect for a RTT setup...
This product looks great, really looking forward to the QD RTT option.
Can you share some close-up photos of how these connect to the factory rails? Also, knowing the height over the factory bars would be nice as well as how many holes are drilled into the rails.
VERY NICE!!!
These are prototype 7/8 roof racks... full replacement rack that uses the same Ruggedized Crossbars for people who already own them.
The Ruggedized Crossbars sit about 1" above the factory rails to have enough clearance for the rails as well as access underneath for bolting.
The Ruggedized Crossbars just slide in to the factory rails the same way as the factory crossbars do.
Just measured, the top of the Crossbar is about 1" over the top of the factory rail.
Closest picture I have on hand at the moment. More are on our Facebook page, though they're down a ways on the page now.
23 holes, with dedicated Maxtrax Pin holes on each side.
I moved my 28-foot ladder 15 miles by wiring on 2 pieces of 101-year-old 2x4. Heavy copper solid core. The full-size 2x4 came out of my 101-year-old house.
Thanks for the feedback. We are prepping to order a bunch of stuff for our 4Runner. I sent you guys a message to your Facebook account.
Cheers!
Just installed my ruggedized cross bars and MaxTrax pins. Now she’s all dressed up with nowhere to go! Thanks [MENTION=136636]jafrush[/MENTION].
peacefulpiranha
