I think mine is bad, it has been overheating only when the weather is hot. I just replaced the water pump and rad cap. Is it easy to replace? How much is does it cost and what other parts do I need? I have no leaks and hoses are good head gasket good also.
Agreed. Not hard at all. I had to replace mine on the return trip across the country from Pasadena to Alabama from the BCS National Championship game. I did it in an Autozone parking lot in Amarillo Texas, at night, in sub-freezing temperatures, with borrowed tools haha. Only a few bucks, a few bolts, and a few minutes later, we were back on the road. :driving:
Good luck!
So you went to the BCS national championship game with the initials UA in the beginning of your username? What are you some kinda Auburn/Alabama fan hybrid? lol...just kidding. I bet you were a Duck fan
No, no, no. You've got it all wrong. I went to LAST YEAR'S BCS championship in Pasadena haha. You know, the one where Alabama beat Texas. :boxer:
RTR
The FSM (page CO-12) says the jiggle valve should be down, not up. Correct torque is 14 foot-lbs. I would torque these carefully. These are three of the bolts that hold your new water pump on and you want that seal to hold for the next 90k+ miles. Over-torquing these (or under-torquing) is not a good idea.
So I installed the Thermostat today, everything is up and running again, thanks everyone for the help and insight!
Thats good to hear. I was about to peg it as an airflow problem and tell you to look into electric fans. The other thing is that Toyotas just run hot. My truck routinely gets up to 209 since I put in the new thermostat.
Sorry to jack... where can I download the FSM? The links under the reference and tutorial sticky don't work.
Which thermostat did you put in the 170 or 180 degree? My gauge reads that I am getting up to 208 degrees and I think it's too hot(this is with the lever turned all the way to the hot position) I sometimes blast the heater to get it back to 203 degrees. I can only imagine what it will read when I have to use the air conditioning. I thought anything over 212 degrees is dangerous since that is the temp water boils. I picked up a new thermostat from Toyota - I guess that it's a 180 degree stat?
