Issue with Power Windows
mrpanic7
Hey guys so I've been searching around and can't find a thread that seems to have a problem like mine.
So I've never had any electrical problems, and randomly one day, only my driver window was working. When using any other switch, none of the other windows will roll up or roll down not even my back glass. I thought it may be the power fuse so I pulled it and nothing worked and after I put it back, The only window that still responds is the Driver window. No other windows roll up or down regardless of which buttons you use to try and use those windows.
Any ideas???:shrug:
According to my Haynes Repair Manual 2003-2009 Models (page 12-32), the wiring schematic is a complete maze. There are 4 different fuses associated with the power window system. There is a 30A fuse (power) and 10A fuse (ECU-IG) located at the drivers side junction block, a 20A fuse (DR/LCK) located at the engine room relay block, and a 7.5A fuse (ACC) located at the engine room junction block.
If all your fuses check out ok, then it may be an issue with the power relay or Body ECU.
Ummm... I hate to ask but it sounds like your window security button in depressed. Should be right there with the rest of the window buttons near the switches.
Any ideas???:shrug:
Did the above ideas work???
So sorry guys. I was having email issues and not getting the notifications that you guys responded :(. I had double checked my security switch but it was kinda sticky... Let me double check that and I will report back. It would be nice to know that was the culprit.
Alright guys so it was my security switch. After playing with it for a bit it wasn't coming up all the way so after I played with it a bit it finally "popped" all the way up and all is well.
Thank you guys for the input and info!:hail:
REE
