I call upon the experts again.
I just finished installing a newly acquired 2006 6-disc JBL unit (MP3) in my 2004 T4R. I originally had the standard 6-disc JBL unit with tape player. I also had a PIE adapter that I used with an MP3 player.
Two issues came up:
1) The unit does not fit perfectly. It appears to be just maybe 4-5mm too far in (see pictures). The standard 2004 JBL unit fit perfectly and the bottom of the face of the unit aligned perfectly with the upper border of the AC controls.
I figured I could get a couple of metal brackets and adjust for the difference, but I have not heard of this issue before; not even from other members that performed the same installation. Am I missing something?
2) When the radio is turned off, there is a very soft buzzing noise that only goes away when I turn the key to Lock position and remove it. I am sure the sound is coming out of the speakers and sounds like an untuned AM frequency at very low volume.
Initially I thought it was the PIE unit that was causing the problem with the 2006 unit. So I removed it completely and reinstalled everything. Unfortunately, the buzzing noise persists. Any thoughts?
Thanks in advance!!
Two issues came up:
Thanks in advance!!
