its been awhile
4runna08
ATTEntion MODS when i log in itll say "Thanks 4runna08 for logging in" then it will come to main page not logged in:bash: someone fix my account please
also i have a 5speed..and the shifting is not so smooth anymore and i have a leak between the transfer case and the tranny so is that my problem?
also my right side axle seal is leaking again so im guessing my diff breather is dirty but if it is..would it just affect one side?
It sounds like your account is working perfectly fine. Have you tried clearing your internet cache and cookies or just trying a different web browser?
yes ive tried that and different browsers. i can only login from my parents desktop so i think my account is messed up.
I've had that happen before too, it was the computer. I tried to log on from a buddy's laptop and it redirected me to the main page after I logged in and wouldn't let me go to my User CP. I've never had a problem with my Mac at home or my HP/Windows 7 at work.
The seal can blow on just one side. Since it keeps happening, the axle housing may be messed up.
What kind of fluid is it that's leaking? Gear lube, engine oil, or coolant?
The harsh shifting could be low on fluid, master cylinder issue, or it's time for a new clutch. You may want to drain the fluid in the tranny and check for debris and the condition of the fluid.
The account will either work or it won't generally speaking. You get some crap on your PC maybe? I'd try to run somethign like Combofix and see if it finds some stuff.
Yea my computer is virus free..the funny thing is my account only works on the crappiest computer in the house:50cal:
So if a mod could please check my account or is there a way to contact a mod?
Also I drained and filled my trans today..It helped abit
Tomorrow I am taking my car to the stealership to do "diff Service" to see why its leaking between the x-fer case and trans
Update
my transfer case is not leaking. the guy said its from the two bolts from the shifter? pretty vague if you ask me. so to fix this leak will they have to remove the trans to fix the leak?
and ignore the stuff about the login issues:toilet3:
workingwheelswnc
