It's my turn with the Check Engine, VSC Trac & VSC Off lights
snowjay
Just started today on the way home from work. Seems to stumble a bit on startup too. Looks like I gotta make a trip to Autozone and rent an ODBII scanner.
Just hit 99k too. What's the warranty on emissions stuff? 100k? or more?
Well I got the scanner from Auto Zone.
The code that was tripped (twice) was P0306 which as the unit said was a cylinder 6 misfire.
Looks like I'll be checking the plug this weekend. They are less than 10k old so maybe I just got a bad one or maybe the coil is going. In any event I have a project for the weekend now.
I cleared the codes it will be interesting to see if they come back but there is definitely a stumble when cold so something must be up.
I have the same problem. Changed plugs, #6 coil pack. still stumbles for about 30 seconds when it first starts then runs fine. What fixed your problem?
