Izuzu rodeo rims on 1 gen?
doesnt matter if they are nice if they are not lug centric youll just break the studs off and do thousands of dollars of damage.
im not doing the leg work for you, you need to look up it up and check yourself if the wheels are lug centric.
Did you try google?
"Many wheels are lug centric and do not require the use of a centering ring. They are typically found on truck and SUV fitments. On these applications, the center bore of the wheel is larger than the vehicle hub diameter to allow for various hub/axle configurations that may have been an option from the factory. These wheels need to be installed with the wheel/tire assembly off the ground when the lug hardware is torqued. This allows the lugs to properly center the wheel and secure it on the mounting surface of the hub."
I also googled "Isusu rims hub centric" and found this forum
Planetisuzoo.com • View topic - can any 6 lug gm rims fit on 99 rodeo
Which they say that they are hub centric.
Before you make a post, type the question into google, youll be amazed what you can come up with.
In this case it doesn't matter what-centric they are, stock Isuzu rims are not going to fit over the 4WD hubs on the front axle, the center holes are too small.
Same with stock Chevy and Nissan 6 x 5.5 rims.
Aftermarket rims will fit.
EnviroHokie
