JBA Offroad UCAS
Did you remove your sway bar to run the Dirt King LCA's?
Also, how do you like the Dirt Kings?
I didn't, I'm just playing around with the idea of it but I've had it off for a few weeks now. Doesn't feel awful due to the spring rate and valving. Can somewhat say it feels smoother due to the suspension actually able to work independently. I'll be able to really test it out this weekend finally.
I like them a lot. Pretty sturdy steering, no vibrations or jolts, much better bushings and nice knowing the uniballs is strong. Keeping them clean can be a pain but it is what it is.
Also, I'm running JBAs older design bushings where they're basically OEM style.
Anyone have any input if upgrading to their new bushing would be much better?
Bump from the dead.
Make sure you use a grease with Moly in it. I did not and have been dealing with a squeaking noise due to using regular hi temp grease from lucas oil. The bushings require a grease with moly to move freely and stay quiet.
I learned that this morning after chatting with the owner of JBA about my squeaky arms.
My new grease should be here today. Ill pump it in and report back if it works.
Upgraded to Toyo AT3 285/70/17 tires today and the alignment tech maxed out my caster at 2.9. Now before I purchase these UCA STD High Casters, I have one important question that I could not get affirmative confirmation while searching online, will they will rub on the tires. My Pro is lifted with Eibach's drop in springs for the factory Fox Shocks and running the factory Pro wheels. Hopefully someone with a similar set up can confirm this for me.
Even after reading their notes I'm not sure where my wheel specs fit in due to them being 17x7 with a +4mm offset, am I over thinking this?
Please Note: 32.5" and larger diameter tires need aftermarket wheels with less then factory wheel back space. Tire Size Calculator
LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, -9mm offset (4.30" backspace)
LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, 0mm offset (4.75" backspace)
LT285/75R16 (32.8" x 11") tire on 16 x 9 wheel, -19mm offset (4.25" backspace)
LT255/85R16 (33.10" x 10") tire on 16 x 8 wheel, -12mm offset (4" backspace)
LT315/70R17 (34.4" x 12.4") tire on 17 x 9 wheel, -25mm offset (4.00" backspace)
Any tire that is 32.2" diameter and smaller there is no fitment problem.
I have std high caster with 285/70/17 and spidertrax spacers. My tires are not rubbing on UCA. I actually had this setup for a few months then added the spacers. Tires never rubbed UCA.
This has been a very helpful thread. The person I bought the 4Runner from had a Rough Country lift installed with N3 struts and V2 shocks. When I had the tires rotated and aligned, they mentioned that it's a little out of spec and recommended getting uca's. Sounds like JBA's will work. Thanks!
JBA Sound Great
I have 9,000 miles on mine.
Glad i chose JBA.
JBA will email you every 6 months reminding you that it is time to grease the fittings.
There are tons of reviews online and on youtube, i suggest you watch and read those.
I have read the same thing. I am jumping between the JBA or the new X-joint from Camburg.
Also Nitro Gears just came out with a similar product. JBA it still a work horse from what I have read.
Tx470
