JBA Upper Control Arms On a 3rd Gen?
These JBA UCAs are not recommended for stock height vehicles but JBA does not have information about minimum fender-to-hub distances required for them to be valid. Any ideas?
Hi. Can those of you running these JBA arms please post the post-alignment cam positions, both front and rear, on your arms please?
the UCA doesn't have alignment cams and what's possible for your rig is entirely dependent on what kind of suspension you have and how large of tires you're using. And even then, you'll probably find it varies from technician to technician.
I was referring to the Lower Control Arm alignment cams. I just wanted to see what the average setup was.
Thanks.
Got my alignment done today. The rear cams are all the way out, where I set them. The front cams are in, or pert near, the neutral positions. I had eyeballed the settings, took it in and the alignment was done in about 20 minutes and the tech nailed the alignment. He liked the JBA arms.
044runner4
