cp99sr5
Last weekend I had the timing belt done, new water pump, Thermostat (part 90916-03075), Belts, Cam Seal, crank seal, etc., along with a brand new radiator, cap, upper and lower hoses and red coolant. Scanguage II temp now is at 205F on average versus the 190F it used to sit at before.
Read about the jiggle valve and the FSM saying install at 6 o'clock, can't determine if its reality/true fact or urban legend/voodoo! The 205F is when outside temps are in the 60's and doing a commute of 29 miles with speeds up to 70 MPH down to freeway, then about half the time in stop and go along with a few miles of street driving taking anywhere from 45 minutes to a hour and a half.
My concern is what happens when temps go into the 90's and 100's and I am running AC full blast or lugging the small boat and camping gear up into the mountains or running a trail? Will I overheat :flame:
Should I worry about this, make the dealership check to see if the thermo is in the correct orientation? I read a lot about optimum Oil Temps, Coolant temps and there is a lot of conflicting information (welcome to the WWW!) Will the 50/50 coolant mix boil at 220 under the 16PSI cap and ruin a trip? I am probably freaking out about nothing but its my runner and I want to take poper care of it. Input appreciated - Chris
