1985taylor1925
Senior Member
Read, he said his shocks are brand new kyb shocks a couple times now.
I don't think steering rack bushings would give your symptoms (mine just had really sloppy steering when mine wore out). But there's any easy way to tell if they're bad. Get down on your left knee right by the driver's door. Rock the steering wheel back and forth a few inches with your right hand as you look at the rack itself under the truck. If it moves at all, your bushings need to be replaced.
I agree with j-money$$$ that the sway bars shouldn't make a difference for this issue. I run no sways too and don't have your problem. Your stock coils may be shot or more likely, your control arm bushings are worn.
Hey i just did the check on my steering rack, and yes I can absolutely see it moving. I imagine that the rack should be able to move a little when under extreme stress since its held in by rubber bushings. But im no expert on the matter. I just orderd the polyurathane set today. Thanks for the advice
