just a quick question!
corny
I just ordered Toytec's Ultimate Lift Kit and am soon to be recieving 285/65/18 Nitto Trail Graps.
Will i need 1.25" Spidertrax Spacers to prevent rubbing?
&is there anything else that i need to avoid any problems with these mods?
Thanks for the help, much appreciated. :]
Whats the backspacing on your aftermarket wheels?
I think you're going to need atleast a .25" spacer but I'm not 100% on that.
Yeah, most likely you'll need that .25". No one can be sure because the same size tires from different brands vary enough that some people will rub with 285s and some won't. It would have been cheaper/easier/better to get wheels with 4-4.25" backspacing and then you wouldn't need spacers.
I'm running that exact setup on my '99 Limited 4WD and at full lock I get a very very slight rubbing on my lower fender but not enough to worry about. I did swap out my UCA's though so that eliminated one of my potential rub points.
