just bought a 1994 toyota 4runner.... HELP!
ok so i just a 1994 TOYOTA 4RUNNER 2WD and it has likely over 200k (odometer stopped working at 160,710 in 2010 so i replaced: the spark plugs, spark plug wires, oil, oil filter, fuel filter, air filter, and added gas additive (iso heat) for the the possible water in the gas from it sitting for 1 year and added oil stabilizer (Lucas) also checked all the fluids and trans was low so i filled it... but while me and a buddy were doing the plugs we accidentally pulled out two of the black hoses which seem like vac hoses on the left side of the top end if your facing the hood, followed them, one was going to nothing just cut clean across and the other seemed to be going to a little breather nipple that we later found under the truck and put back on. It was idling a tiny bit rough before but after the deal with the hoses and other things i changed sometimes right when i start it it idles really rough and if i don't hold the gas steady and wait then put it in to reverse it just stalls out? any ideas?? sorry for the short story i just wanted to state everything that happened with the truck
2001ATL
