just bought Toyota 4Runner White Interior LED Package (10 Pieces)
berjaya2015
I'm rating these items a "5" primarily for the exceptional value that they are. Really, a whole kit of energy conservative, modern looking lighting for ONLY $15!? How can you beat that?!
The items were shipped quickly, packaged sufficiently, and even included a little bonus LED flashlight as a surprise. Hey, it's a cheesy, cheap flashlight, but it was still nice to have the surprise.
Install was very simple. Took me probably 20-30 minutes. As mentioned from other reviewers, here's a couple things to know:
-LED lights are different then traditional bulbs. There will be a 50/50 chance that you're bulb won't light up, so you'll just have to turn it around and try the other way. There's polarity involved on LED lights.
-The courtesy lights required me to adjust or tweak the metal prongs to make an appropriate contact. So, don't become frustrated. If your lights aren't working, check the prongs, and don't forget to do as above, and flip too.
-The dome lights are indeed a very tight fit. You have to carefully apply pressure to ensure that they are fully inserted.
-The courtesy lights are within a plastic housing with no reflecters inside. This actually works out ok because if there were reflectors, these door courtesy lights would probably be way too bright and look "ricey" as some people called it.
I bought these about a year ago, they are worth the price and are very bright. Compared to the oe lighting, I'd say the brightness increase from 1-10 is about a 9.
Good value for the price, easy upgrade
I also bought these about a year ago. They've worked great and they're really bright and for the price I don't think anything is beating them!
these just came in ytday...bought from amazon...it included reverse and license lights!. 14 pieces...the reverse lights look cool with the red rear lights at night!....makes the truck look high end, and also compliments my cheap spec d halo drop in hids assy.
white light is cool
quick question....how did you remove the dome and cargo light housing to fit the led bulbs?
white light is cool
You can use a flat head screw driver to gently pry the lenses from the assemblies. The lenses have little clips built into them that keep them attached. I found prying from the outside edge (toward the closest respective door) of the map lights made it easy to remove them. The domes have clips all around.
:offtopic:
Speaking of your HID assy, how do you like it? Almost pulled the trigger on a set last year but decided sliders were more important... Can you PM me some pics of their light output?
If I didn't know any better I'd say the OP is a pretty good salesman! That opening post reads like an advertisement.
Is this the kit I need to do my dash cluster, clock, ac controls, and other switches? Just bought my first 4runner Saturday and hate that dim orange cheap looking glow. The white light looks much cleaner. Thanks
nope, this is just for interior, not dash...i believe i have seen a kit for the dash somewhere on this forum?.
[MENTION=105200]Ohcrymore[/MENTION] would post pics later, though i posted the pics back then, you could search my old posts - what did you do to your 4runner today.
the lights are ok, gave my truck a whole new look, the cutoff isnt as sharp as oem projectors and the halos arent bright enough in sunlight.....unlike the lightwurkz halos. i did rate it 6/10 overall
sure its an advert, he posted such all over the forum.....good advert though!, his write up made me bite the bullet and place my order:fishing:
