Chuckles' 98 Manual SR5 4Runner
Chuckles89
General information:
1998 Toyota 4Runner SR5 4x4
3.4L 5VZ-FE V6
R150F 5-Speed Manual Transmission
Standard 2 Speed J-Shifter Transfer Case
4.10 Diff Gears
285,550+ Original Miles
Modification/ Repair List from 2013 and up
ENGINE
Original- Not Rebuilt
PCV Valve and Grommet
Silicone Vacuum Hoses
Toyota Oil Filter
Denso Spark Plug Wires
Valve Cover Gaskets
Tube Seals
Half Moons
Camshaft Seals
OEM Battery Tie-down
Battery Area Rust Removal + Paint
Denso Copper Spark Plugs
Throttle Body + Intake Plenum
Castrol GTX 10W-30 Motor Oil
Mitsuboshi Timing Belt
Aisin Water Pump
OEM Oil Cooler Line
Toyota Thermostat
Koyo/ NSK TB Rollers
Radiator Flush
Toyota/ Mitsuboshi Acc. Belts
PCV and Engine Breather Filters
OSC Tacoma #1985 Dual Core Radiator
Motorad Radiator Cap
Gates Radiator Hoses
Denso 80 amp alternator
INTAKE
Deckplate mod
High Engine Bay Snorkel
ISR Mod
MAF Sensor Cleaned
EXHAUST
Dynomax Super Turbo w/ stock 2.25" piping
Past- Thrush Welded, Walker Quietflow, and Straight Piped
DRIVETRAIN
Synthetic Valvoline 75W-90 Transfer Case
Valvoline Conventional 80-W90 in Front Diff, and Rear Diff
Redline MT-90 in Transmission
Transmission and Transfer Case Shifter Boots, Gaskets, and Grease
Rear Driveshaft Grease Zerk replaced
ADD 2 Low Mod- removed
Aisin Manual Locking Hubs
Manual Front Diff. Conversion (ADD Delete)
OEM Used Taco CV Axles
Aussie Locker in rear- removed
Cable Actuated Toyota E-Locker
Transmission/ T-Case Extended Free-Flow Breathers
Free-Flow Rear Diff Breather Extension to tail light
Aisin Clutch master and slave cylinders- 2016
Marlin Crawler clutch- 2016
OEM Toyota Front Wheel Bearings
National front axle seals
Timken rear wheel bearings
Doorman rear ABS rings
OEM Rear axle seals (inner and outer)
Doorman USA Made Lug Studs- rear
BRAKES
All Stock Sized
Red Front Calipers
Red OEM Drums
Toyota Pads- removed
Front Soft Lines- Napa
Driver’s Side Hard Line- Custom
Red parking brake cable
OEM Rotors
Wheeler's Rear SS Line
Wagner shoes
Doorman wheel cylinders
Akebono Pads- best pads I've ever used. I'm sold on them for life!
SUSPENSION
Duralast Front Sway Bar End Links
Toyota ’99 Tall Coils- rear removed
KYB Monomax Struts
KYB Front Spring Isolators
Rear sway bar removed
AirLift 1000 in Rear- removed
Front LBJs- and passenger again in 2016
LBJ Bolts
Tie Rod End Boots- Polyurethane
PolyTuff Rear Suspension Bushings
Prothane Sway Bar Bushings F&R
Energy Poly Steering Bushings
LC Tokico Rear Shocks (free blown ones lol)
Used OME 890 Rear Coils
WHEEL + TIRE
Street Tires: (set of 5)
4Runner 16” Split Spoke Wheels- Painted Black
BF Goodrich All Terrain T/A 235/85/16- lots of chunking
OEM Chrome Lug Nuts
Trail Tires: 235/85R16 Cooper STT Pro on 16" split 3 wheels painted gray
ARMOR
Stock gas tank and t-case Skid Plates haha
Doubled up gas tank skid coming soon
Lotus Rear LCA mount skids- red!
Savage Offroad Front Plates!
EXTERIOR LIGHTING
'99 Headlights- removed
Stock Tail Lights
Switchback LEDs Up Front
Depo Clear Front Turn Signals
LED Marker Lights
LED Flasher
Hi- Mount Stop Light- New Bulb + Cleaned + LED
Morimoto Mini H1 HID Projector Retrofits
LED Fog Lights
LED Brake Lights
LED Turn Signals
LED Reverse lights
LED 18W Pods in front x4
2x 18W Rear LED Pods
ELECTRICAL
OEM Towing Package
Red Horns
3 Gauge Ground Wire
Aftermarket Battery Terminals
OEM Fuse Box Cover
Driver’s Door Sensor Cutoff Switch
Fuel Pump Kill Switch
Seatbelt Sensor Delete
ABS Disable Switch
Airbag Disable Switch
CB Radio
Firestik Antenna
Ford Fiamm Horns- removed
Baofeng HAM Radio
Harbor Freight Air Horns- one of my favorite cheap mods- only $12 and they make me smile :) haha
EXTERIOR STYLING
SR5 Fender Flares- Removed
Rear Spoiler
Roof Rack
“Manual” Badge- removed
OEM Windshield Wiper Arms
Running Boards Removed
2nd Gen 4Runner Rear “4WD” Mud Flaps- removed
Reflectors on Hitch- removed
Plastidip Rear Emblems
Hitch Inversion
Red Tow Hooks
2nd Gen 4X4 Left Tow Hook
Debadged Rear Hatch
INTERIOR STYLING
Oak SR5 Cloth Front Buckets and Rear Bench- 120,000 miles as of April 2016
Driver’s Seat Bolt Repair
Oak Cargo Cover with Headrest Flaps Removed
4th Gen 4Runner Front Floormats
4Runner Embroidered Oak Cargo Mat
Clutch Pedal Helper Spring
8-Ball Shift Knob
Oak Leather Headrests
99+ Center Console with Cup Holders- Custom Rear Heater Cutout
OEM Clutch + Brake Pedal Covers
Seat Bracket Covers Removed
Driver’s Side Grab Handle
Ash Tray
Door Weather-stripping
Large Storage Compartment
Sound Deadening Throughout
Vinyl Floor
Plaid Center Console Lid
OEM Rear Floormats- Carpet
INTERIOR LIGHTING
LEDs
LED Cargo Lights
LED A/C Lights
Sylvania Incandescent Gauges
LED Hatch Lights
INTERIOR ELECTRICAL
Sunroof Switch Replaced
Sunroof Motor Replaced- junkyard used
New Ignition Cylinder
Dual Power Outlets in Front Passenger Area
A/C Switch
Clutch Start Cancel Button
VIP RS3000 Alarm
Remocon Remote
Relocated Antenna
Uniden 520 Pro XL CB- died
AnyTone Smart CB
SOUND SYSTEM
Stock Tweeters
Polk 6.5” with Tweeters Up Front
Kenwood 5.25 with Tweeters in the Back
Kenwood Excelon Single- DIN Head Unit
Stainless Steel Whip Antenna
Sound Ordinance 8" Sub
Been there, done that:
Tennessee:
Prentice Cooper
Bigfork
Coppinger Cove
Pickett State Forest
Hickory Flats
Cedars
Blackburn
CH
Windrock
Standing Stone
Catoosa
Nemo
Skinner Mountain
Alpine Mountain
Big Bottom
Kentucky:
LBL
Turkey Bay
Colorado:
coming soon
Wyoming:
coming soon
Montana:
coming soon
Idaho:
coming soon
Timeline: http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-5.html#post1852390
Links throughout build thread. Updated 2-12-2018
AC Delco Rear Sway Bar End Links http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-3.html#post1832517
Air Conditioning Idler Pulley Bearing http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2870578
AISIN Hub Bolts http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-57.html#post2904829
AISIN Hubs http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-25.html#post2133362
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-25.html#post2137170
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-28.html#post2209403
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2210237
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2219808
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2223758
Alternator Pule Repair http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-55.html#post2832126
Alternator Rebuild http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-53.html#post2774786
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-53.html#post2776310
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-54.html#post2782520
Aussie Locker http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-33.html#post2261529
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-35.html#post2268128
Awning- http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-49.html#post2640403
Big 3 http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner.html
BFG KOs and 99 Suspension http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-3.html#post1828846
Bumper painting http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-12.html#post1963723
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-16.html#post2014953
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-17.html#post2019171
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-18.html#post2041837
Brake Shoes http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2870578
Cabin vent filter http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2222670
Camping Stove http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2562101
Camping window vents http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-25.html#post2137170
Cargo boxes http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-31.html#post2230243
Cargo storage box enlarged http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1884660
CB antenna http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-21.html#post2099202
Clutch/ Rear main seal/ flywheel http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-37.html#post2366929
Cooper STT Pro- 235/85R16 http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-52.html#post2724640
Driveshaft Zerk Replacement http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-3.html#post1837196
Dynomax Super Turbo Muffler http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2530176
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2530200
E-Locker Axle swap (includes rebuild of axles and brakes) http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-42.html#post2473208
http://www.toyota-4runner.org/3rd-gen-t4rs/225657-how-rear-wheel-bearings-seals-home.html
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-44.html#post2507502
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2562879
E-Locker Cable Conversion http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2525873
Fender rust fix http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-43.html#post2488151
Field Monitor Unit http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2526822
Firewall clearencing for tires http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-39.html#post2403584
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-40.html#post2448084
Front Bumper- http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-50.html#post2660391
Front diff- ADD Delete http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2219795
Front mud flaps http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1887943
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-19.html#post2052229
Hatch wiring fix
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2569045
HID Morimoto Projector Retrofits http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2556359
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2564757
Hidden Snorkel http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2533897
High clearance front bumper http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-21.html#post2086216
High clearance windshield washer fluid tank http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-46.html#post2569045
High flow air box http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-4.html#post1847337
Hitch flip http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1884660
ISR http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-6.html#post1874195
K&N Filter http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-12.html#post1963723
Land Cruiser rear shocks http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-36.html#post2313749
LBJ Replacement http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-11.html#post1930489
LED Pods http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-22.html#post2099209
LED Revese lights http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-25.html#post2137170
Lotus control arm mount skids http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-33.html#post2261529
NOCO GB40 http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2871441
Oil Cooler Seals http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2882284
Oil pan gasket http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2219795
Off-Road Low Lift Jack http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-43.html#post2492269
PCV Filter http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-6.html#post1874195
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2551983
PCV Valve + Grommet http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-57.html#post2904829
Plastidip Emblems http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1884660
Polyurethane rear bushings http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-20.html#post2068092
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-20.html#post2079258
Rear Bump Stop Extension http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2870566
Rear bumper http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2551983
Rear diff breather http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2222663
Redline MT-90 http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-39.html#post2416590
Rock Lights http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner.html
Roof Basket- http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-49.html#post2640396
Rubber steering wheel upgrade/ downgrade http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-18.html#post2041841
Savage Off-Road Skid Plates http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-31.html#post2230243
Savage Off-Road Sliders http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-23.html#post2124092
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-24.html#post2132190
Seat swap http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1887943
Shift Knob http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-6.html#post1874195
Sleeping platform http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-51.html#post2702429
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-51.html#post2709352
Sound deadening- peel-n-seal http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-10.html#post1923431
Steering Rack Replacement (AAE)- http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-49.html#post2640410
Stereo upgrdes http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-4.html#post1847337.
Sub- http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-21.html#post2099202
Super Swampers http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-39.html#post2403584
Switch panel http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2219805
Switchback frint turn signals http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-11.html#post1944981
Tacoma OSC 1985 Radiator http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-45.html#post2551983
Tie Rod End Boots http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-11.html#post1930494
Timing belt/ water pump http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2219800
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-29.html#post2222675
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-30.html#post2226463
Thrush welded muffler http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1887943
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-11.html#post1930856
Tom Wood's Driveshaft http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-56.html#post2878776
Transmission cleaning http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-37.html#post2366931
Valve Cover Gaskets, PCV Valve, SPark Plugs, Half Moons, Tube Seals, Cam Plugs, etc. http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-3.html#post1837196
Vinyl Flooring http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-7.html#post1887943
http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-10.html#post1927560
Walker Quietflow Exhaust http://www.toyota-4runner.org/3rd-gen-t4rs/178792-chuckles-98-manual-sr5-4runner-3.html#post1837196
Original Post:
After a search of almost two years of searching for a manual Toyota car or truck, I finally got one! It is a 1998 SR5 Manual truck with 240,000 miles. Bought it for $2900 last night and I sure am excited! The possible name is "Diamond in the Rough", but that probably won't stick. It needs a lot of work to make is safe. More details will come soon. I don't have any pictures at the moment except for the dealer ones:
That's my boy! I called her "a diamond in the rough" last night. Luckily, looks like mostly lots of little parts. Not one dent on the skids, almost no rust (two quarter sized spots where no one sees), and straight. This will be my 3rd 4Runner project. I sure miss "Old Blue" (what the guys at work call my old 4Runner).
Stephen :hug: hug from Chuckles
PS - long time no post
chuckles, i see you posting all the time in the classics section because of your dads runner. Glad to see you joined the 3rd gens. Goodluck with your runner. What kind of work is needed?
Thanks guys! The most important work is sway bar end links (I did one last night), shocks and springs, valve cover gaskets, headlights, taillights, and a battery tie down. I have a more complete list and will post it when I get on my desktop computer- I will also post some pics. I also need to degrease the engine, front diff, and transmission to see where oil is leaking from.
Chuckles busted his first knuckle last night. He's now part of the club! :lmao:
And he found out how hard it is to remove a single nut. I have never removed an 18 mm nut on Toyota until last night. I have a socket that size but no wrenches. I guess that will change soon. I'll let junior fill y'all in. But it is amazing what a sway bar end link does.
Stephen. :snacker:
Nice find Chuckles. I see the top doesn't come off, but I guess you can't have everything right?
I can't wait until my boy is old enough that we can start on his first truck.
I'm still in the process of making a list of things to do, so that will come in a little bit, but here are some pictures:
Bye, bye broken running boards!
Dirty engine runs great, just needs valve cover gaskets to stop the oil leak
Bad spot under the battery
Broken driver's seat... the front left bolt was ripped out of the floor, so we drilled through to the bottom and put a regular grade 8 bolt in. It needs replacing badly
Needs a center console- I want to find one out of a '99+ to have cup holders
Dirty back seats
Unused jack
Sway bar end links- broken one and a new one from autozone
I have a couple of questions:
Will 4 spoke 15" alloys from late 1st gens, 2nd gens, and t100s fit on the 3rd gens? Also, has anyone rigged up some rubber mud flaps that say "4WD" from a 1st Gen 4Runner or a 4wd pickup for the front and rears in place of the SR5 flares and running boards?
4 spokes will only fit if your truck came with 15" wheels from the factory (the door jamb sticker is a damn liar, check your wheels.)
The 15" models came with smaller front brake calipers. The 16" wheel models (standard only on Limited, both base and SR5 can have 15") came with larger calipers (S13WM casting) that will not suit a 15" rim.
It should be noted that all 3rd gen 4Runners can be upgraded to the Tundra brakes, 231 or 199mm. Of the two 3rd gen 4Runners I have, both have 231mm Tundra brakes (13WL casting). For this you should run at least a 16" rim, although the original 4Runner 6 spokes will not work for this.
Mudflaps can be done, it's all screws after all.
The 15" models came with smaller front brake calipers. The V6 model came with larger calipers (S13WM casting) that will not suit a 15" rim.
Thanks for the quick reply! That's a bummer about the wheels though because the tires for 16s are so expensive.
Been working on it all weekend…
Box of Parts!
First was the battery tiedown. When I got it, it had a bungee cord and it broke, so I added some rope. Now it has a real one.
Pedal Covers
Windshield wipers
Sunroof switch worked for sliding forward, back, and tilt up. The tilt down didn't work, so we got one from the junkyard
Also got a fuse box cover that can be read from the junkyard
Then the cleaning started:
Before
After
Before
After
Cleaned the back seats and the seatbelt
After cleaning all the plastics, the headliner looks dirty lol
Started cleaning the hood
More pics to come…
Also, at the junkyard, we got some leather headrests for the front seats
Some of the dumb things we have found are:
1. The clutch pedal could have fallen off at any time due to the pin holding it to the clutch pedal bracket was put on wrong and was missing a cotter pin
2. The slave cylinder was held on by mismatched bolts, which were loose
3. The front skidplate was held on by one bolt and two zip ties
4. Vacuum hose not connected on the VSV
I'm about to go and scrape off the 1/4" oil/ grease junk that is built up on the front of the truck under the engine. I'm also going to change the rear diff fluid today.
What are you using? remember to unbolt the fill plug before the drain plug. If you unbolt the drain then the fill won't come out then.... yeah. no bueno.
I did check the fill plug before doing it (thanks to nervo19's story of finding out that the fill plug was JB Welded after he drained it). I used Valvoline conventional 80W-90 GL-5. The old fluid was black, brown, and green.
Took off the fender flares. Just need to polish the paint and get some mud flaps. My dad cleaned off the nite shades with goof off!
erinobr2000
