A timing light is for checking the ignition timing (the timing of the spark plugs firing). The timing belt is related to "mechanical" timing (the timing of the intake and exhaust valves opening and closing in relation to the pistons going up and down). These are two totally different timings. You should have a good understanding those concepts.I just did my timing belt and just got to throw the belts and coolant back in. I got all the marks lined up on the belt to the cams and crank pulley, how will I know if the timing is good? Can I use a timing light to check it?
