Just finished installing new sliders
slider76
My buddy helped me out tonight. Over the course of about 2.5-3 hours we got my freshly delivered Shrockworks sliders with tread plate installed on my 18 SR5. A couple notes:
1. You will need to drill in one location on front passenger side to secure the bottom bolt.
2. You will want a bottle jack or floor jack and a piece of lumber to support the fuel tank.
3. We also used a jack to support the sliders as we were bolting them to the frame.
4. Stick nuts are tricky, but doable.
I am not mechanically inclined, and I was able to do this. If I can do, you can do!
Agreed with others, why you need to support the fuel tank? I didn't need to when I installed my sliders by myself.
OP: Would you provide some photos of this install?
Maybe that will clear up the reason why you had to "support the fuel tank".......
Why did you have to support the fuel tank?
Yeah, what does the fuel tank have to do with this install? Shouldn't even be a concern with this.
I have the Shrockworks sliders and installed them 3 years ago with a friend. I can't remember exactly since it's been a while but I believe the OP is correct. You remove the bolts on the driver side frame that supports the fuel tank skid and also the fuel tank strap bolt. You re-use the bolt locations on one of the legs of the slider. This might be a Shrockworks sliders install thing only so if you don't have a set of Shrockworks sliders then this likely would not have applied to you. Just backing up the OP here since he's correct.
I have the Shrockworks sliders and installed them 3 years ago with a friend. I can't remember exactly since it's been a while but I believe the OP is correct. You remove the bolts on the driver side frame that supports the fuel tank skid and also the fuel tank strap bolt. You re-use the bolt locations on one of the legs of the slider. This might be a Shrockworks sliders install thing only so if you don't have a set of Shrockworks sliders then this likely would not have applied to you. Just backing up the OP here since that's correct.
Thank you for the explanation!
I have been looking at sliders but did not realize they attach using fuel tank bolts for support. That is why I asked the OP for a photo so I could see this.
Anyone know if other brands of sliders install like Shrockworks ?
Same here, I am shopping for Sliders and a front bumper, Sliders 1st. I am looking for bolt on. I had P&P engineering on my Xterra and they just bolted to where the stepsides were. on my other Xterra I had Shrockworks and they just bolted right up. If I cam off as a dick i'm sorry I just ever heard of the fuel tank being involved with bolt on skids. I guess I need to ask all the vendors now.
Thank you to OP for posting about your slider install.
With a quick Google search I answered my own question about having to remove fuel tank support to install sliders. Probably no surprise to those who have done their own install, but I found some manufactures do and some don't require this procedure. I found this short video showing install of RSG sliders to be in line with what I imagined a slider install would involve.
http://www.youtube.com/watch?v=1pmki8RY4JU
Thanks again -- I had no idea!
"huuuuuuuuuuuge"
