just installed lift, need help tightening up steering/handling
theizzardking
just installed my ome lift and the ride feels a bit loose, like i need a stiffer shock or spring maybe, i have 882's in the front and there isn't too much body roll so i'm not thinking new sway bars quite yet, do you guys think a poly bushing kit would help firm things up a bit? i understand it's not going to feel the same as stock since i just upped the cg by a few inches but, is there a way to make it track a bit better and just make it feel tight, if you know what i'm getting at.
this has me at a lose since most people with the 882's complain of them being to stiff, i'm getting new tires on saturday so i hope an alignment helps a bit but i'm thinking that 222K on my bushings isn't to good, whudda think?
well im not too sure about the whole replacement of bushings since im still running the stock ones but the alignment will help out SO much and will make it feel much better... I would hold off until u get the alignment first and if u feel its still loose to u then maybe change out older parts.
yeah i'm waiting till this saturday when i buy my tires todo the alignment, i just came from lez schwab and i noticed they were selling adjustable ball joints, do you know if those would beneficial to those of us running lift?
