Just when I thought my 4R couldn't run any better...
thegipper
97 auto SR5 208k miles
Since inheriting my 4R from my brother, the one thing that I have been most confident in was the motor. It has already ran very well in 8 months since I've had it.
Just for shits and giggles, and since I have replaced and fixed up so many other things on this rig, I figured why not change my spark plugs and pcv valve.
My brother never changed either of them and he bought it with 160k miles.
I purchased an OEM PCV valve and new grommet from my local stealership. I bought 6 new NGK dual electrode spark plugs (whatever the correct ones are) and dove in.
The spark plugs, in all honesty, were WAY easier to install then I thought they would be. I've worked on other vehicles that were definitely much harder than the 5ZE-FE. The plugs I removed were all Denso, so I think they were changed at some point. They didn't look terrible but were anything but new. Cylinder #5 spark plug had oil all over it, the rest were clean. This is also the approximate area where my VC is leaking, probably from the half moons/cam seals. That's next on the list.
Next up was the pcv valve. I let it warm up for a good 20 minutes then shut it down. I unplugged the vacuum hose (cracked, fixed with electrical tape) and yanked it off with a pliers. Piece of cake. Removing the grommet was another story. It broke off into a million pieces but no big deal, fished them all out with needle nose pliers.
I installed the new grommet and PCV valve and fired it up.
WTH, holy shit. This engine sounds like it is brand new. Now again, it always ran perfect and to me, sounded excellent but now it sounds even better. It runs so smooth and quiet, its hard to believe.
My 3GR-FE in my Camry and Highlander (both very low miles running true full synthetic oil) are substantially louder. Now they both run very well too but this 4 runner continues to amaze me.
Here's to another 100k+ miles!:trophy:
Unknown mileage on the plugs I took out. Not great but I've seen waaaay worse.
Sent from my SM-N910V using Tapatalk
Yeah the 5VZ is arguably the most reliable engine by toyota, mine has 283k miles is quiet smooth and uses no oil. you have oil on the plugs due to the seals around the spark plug tubes, not a big deal, just absolutely do not use felpro blue garbage gaskets get OEM. When you do get around to replacing the valve cover gaskets remember there are 2 half moons on each head, and the often forgotten plug on the back that needs to be re sealed, easiest to remove that back cap, clean apply FIPG re assemble. keep oil and antifreeze in it and it will go forever.
I think the forgotten one you mentioning is called the cam plug.
Shoot. I just got a felpro blue valve cover gasket for my corolla. Are they not any good? Got it from Rock A. At least on a corolla it is quick and easy to change.
Are there any oem valve cover gasket kits on ebay that have everything you need other than maybe the fipg?
Can you snap a picture of the PCV valve?
I haven't spent much time under the hood of our 4r, but I'm sure that should be changed this summer.
Are you not sure where it is? I'm at work and don't have the 4R here. Let me see if I can find a picture of where it is. Its on the passenger side valve cover, all the way forward towards the radiator, right behind the timing belt cover. It will look like a 90 degree plastic elbow with a hose connected to it. There will be a rubber grommet that it is pressed into on the valve cover.
There really isn't a reliable way to test it. My suggestion is if you have never replaced it, just buy a new OEM pcv valve and grommet and replace it. It only costs about 17 bucks.
Here you go. This only applies to the 3.4 v6, not sure where it is on the 4 banger.
