KCMO - '06 SR5 - Build Thread
overlandout
Moved from new owners forum to here.
But this seems like a good place to get started, plan out next steps, and keep track of what in doing.
I live in KCMO. Just got my 2007 V8 SR5.
Purchased with 148,500 miles.
Building out the little things right now. Budget is tight for a while.
Big things down the line though.
Long term goal is to make this into an overlanding rig (or maybe just car camping/glamping).
First picture is how I purchased it.
Current:
Mods and accessories
  • Auto Vent Shades (in channel)
  • Pfran interior LED swap
  • Smokers Kit
  • Debadged
  • Removed running boards
  • Removed HCF
  • Weathertech floor liners
  • Afe dry filter
  • Aux Beam High, Low, and Fog
  • RAD Rubber Designs Splash Guards
  • Yellow Vvivid Tint on Fogs
  • Blue Sea Fuse Block and Circuit Breaker
  • Aftermarket blackout headlights
  • Roav Dash Cam
  • Backup Camera
Maintenance
  • 148,600
  • Seafoam spray
  • Seafoam oil
  • Seafoam gas
    148,700
  • Oil change
    150,000
  • New battery
    151,000
  • New air filter
  • Replaced gasket on gas cap
  • Replaced low beams w LED
  • New OEM Front Calipers and Brake Pads
160k
[*]Flushed Power Steering Fluid
[*]Another oil change
[/LIST]
To do
  • Dash cluster lights
  • Dual battery
  • Storage and sleeping platform
  • New Suspension (Planning for Bils 5100 and OME)
  • New Wheels? Not sure what to get though.
  • YotaMafia Grille
  • Lamin-X clear covers for headlights
  • Considering tinting the taillights
  • Rock Sliders
  • Ditch Lights
  • Some day an RTT
  • RokForm / RAM Mount for phone
Looking for dash cams and backup cams
Would like to run the backup cam through a JVC KW-V230BT
Sent from my SM-G950U using Tapatalk
Changed out spark plugs over the weekend. Looks like the previous ones were relatively new.
Also replaced a few neo3 backlights in the hvac controls. More lights to come.
Need to replace info screen backlights as well as some SMD lights in the dash.
Also nearly finished installing my backup camera. Lots of obnoxious panels removed to route the wires.
Last weekend I had a hell of a time doing a brake upgrade.
Bought the Power Stop Z23 kit for 5th Gen.
Lessons learned:
Always use anti seize on your hub/rotor/wheel
Always clean the hub to get rid of rust before putting on new rotors
Be careful with the parking brake when removing rear rotors
Definitely don't use 5th gen rear rotors (The "hub hole" is 2mm too large and will cause them to sit off center.
Also, saw that I had a torn boot on the power steering. Ordered new ones and will install tonight.
Going to need to chill out on upgrades for a while. Taxes, brakes, and tires soon have really set me back.
Lessons learned:
Welcome! Nice rig! Always love seeing the silver 4runners.
I'm doing my brake pads + rotors in weekend but it's just a straight replace, hoping I don't run into this much trouble.
Did a little bit this past week. Installed RAM phone mount. Replaced almost all the HVAV LEDs.
Installed the overland equipped fuse block mount with blue sea fuse block. I have a circuit breaker for the hole on its way.
I'm at about 160k miles.
Just did a power steering flush. Definitely notice a difference.
Also just got my sprint booster. It does make it more fun to drive, but i suspect it's less comfortable for passengers. At least when accelerating from a stop.
Vvivid air tint just arrived. Light smoke for headlights and taillights. Yellow for fogs. Still waiting on halo LEDs before i blackout the headlights and put tint on.
erinobr2000
