There are several threads on the Kenwood DNX series of Garmin based Nav radios but most are lacking in pictures. I took some pictures of my install into my 4th Gen that I thought would help others and figured I'd also post some links to threads that helped me prepare. I installed a DNX6960 which is the same radio as the DNX6160 but the Excelon line. I think the only benefit is the longer warranty which with a combo unit like this; is nice.
This is actually a fairly easing install in the JBL system because you have to buy the PAC Tato which has much of the wiring harness pre-done. I only had to connect the power, acc power, ground and reverse. A question that I saw over and over when doing my research was about the power antenna booster. The Tato harness has that wired into it (pin 13) so you do not need to connect the blue antenna power wire from the Kenwood harness (I verified this with a multi-meter).
To start here are some instructional links.
How to take apart your center console and dash for the install.
[edit: That site seems to be down but here is another site that has instructions for taking apart the dash to the radio as part of a Navigation Bypass Install.]
Threads about this radio - here, and here.
Wiring connector pinouts for JBL system including the amp.
4th Gen reverse wire location
I thought the install tips in here were good even though it's not DNX specific but still forgot to take the CD out of the factory player.
What I bought:
1. DNX-6990 - about $735 from Amazon
2. CA-SR20V - Kenwood Sirius Cable - about $15
3. Sirius SCC1 - Sirius Radio Receiver - about $40
4. KCA IP3011V - Kenwood iPod adapter - about $30
5. Cable Jive - iPod to USB adapter (so I can use the iPod 30 pin connector with a thumb drive - there is only one USB port on the back of the radio)
6. PAC TATO - JBL stereo harness/interface - about $60
7. PAC SWI-JACK - Steering wheel interface - about $45
8. generic ebay rear view cam (actually for a Prado but not an exact fit)
Not pictured
*Mini-usb to USB A male cable. I plugged this into the back of the radio and left the other end hidden beneath the center console power adapter. This allows me to access the GPS for updating and other changes with a laptop. Note you can do most updates with a micro SD card but this is more versatile.
*Urban Runner Trim Ring. Yep, it's pricey but really looks good. Toyota part number
Z365-35904 Desc: PANEL SETRADIO RECE Price: $88 [edit:it looks like this part will only fit the SR5 non RDS JBL center dash. If you have a limited with an RDS JBL unit you'll need an aftermarket kit like the one mentioned here later in the thread.]
What I bought:
Not pictured
