Key FOB Programming
bpearson
Hello all
I purchased a 2006 4Runner Ltd a few days ago from Carmax and my baby has only 1 key fob. I still have the key fob from my dearly departed 2000 4Runner (may she rest in peace).
Is it possible to re-program the key fob to work with my new 4runner?
If possible does this have to be done at a toyota dealership? I appreciate any insight that you all may provide!
BTW I am new to this forum, so forgive me if this has been posted.
This is really wierd, but I also traded in my 2000 ltd for a 2006 ltd., about a year ago. You didn't happen to go from black (2000) to white (2006).
Anyway, back to the subject at hand. My truck only came with one keyless remote and I too had to get a new remote and key. I bought a remote similar to the one in the link below. I paid $15 for mine on ebay in april of 2008. It works great, have not had any problems with it. The only problem was dishing out the $70 to the dealership to program the new key I bought. The remote that is in the link that I attached also comes with the programming instructions. Make sure that the FCC ID# and the IC# on the back of your remote match the numbers on the auction your looking at.
http://cgi.ebay.com/ebaymotors/2005...c0.m245&_trkparms=72:1205|65:12|39:1|240:1318
According to all the listings on ebay, I don't think that it is possible to program your 2000 remote. Most auctions I have seen do not include a large spread of years. Do your research, but I don't think it is possible.
Yes it is weird. My last 4Runner was silver and my current 4Runner is meterorite metallic. I can tell you that the 06 rides 100% better than the 00.
Thanks for the information, I will purchase another remote and have the dealer program it for me.
Thanks for the information, I will start bidding on a remote and have Toyota program it for me.
When you get the keyless remote, programming instructions should come with it. You program your remote to operate your locks, windows etc....
You will only need to include the dealer if you need to buy a new key, they have to program the key to work for your vehicle. I think it has to do with the chip needed to start the vehicle, something to do with the anit-theft feature.
Hope this helps.
Don't take it to the stealership to program. It is very easy to do it yourself. If you buy a fob on ebay it should come with instructions. If not I will post them below.
Programming for a 2003 to 2005 Toyota 4 Runner
When
Remote transmitter added or replaced.
System malfunction.
How
Driver's door open, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
Switch ignition ON and OFF once to program a remote transmitter code whilst
retaining the original codes or twice to program a remote transmitter code
whilst erasing the original codes. Three times to check how many remote
transmitters are currently registered or five times to erase all registered codes.
Remove key from ignition switch:
System should now lock and unlock vehicle once, twice or five times
depending which mode has been selected. One to four times, slowly, to
indicate number of remote transmitters registered.
Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds -
Within 3 seconds:
Press LOCK button.
System should now lock and unlock vehicle once to confirm registration,
twice to indicate registration has failed.
Within 40 seconds:
Repeat button procedure to program remaining remote transmitters.
NOTE: To exit programming mode: Open driver's door.
NOTE: A maximum of 4 remote transmitters can be programmed.
It may take a few tries and the timing must be very accurate to work but with a little patience it is easy.
06-07 Programming
Here is the procedure that Worked for my 2007 Limited 4WD V8
Credit to "Count_Olaf" for the post over on yotatech forums
Hey all, i was gonna drop this in a new thread. i bought a replacement key fob off ebay and all the instructions i found here on yotatech didn't work for me. so the ebay seller sent me instructions on how to get it done and it was significantly different than what i found on here. Just wanted to get these instructions out there to help poor slobs like me. and when you program it , dont think about this too long, you have to scoot through the sequence at a pretty good pace.
1. Driver's door open, key removed from ignition switch.
Within 5 seconds:
2. Insert and remove the key from the ignition switch twice.
Within 40 seconds:
3.Close and open driver's door twice.
Within 40 seconds:
4.Close and open driver's door twice.
5. Insert the key into the ignition switch and close the driver's door.
6. Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitters are currently registered or five times to erase all registered codes.
7.Remove key from ignition switch:
Within 40 seconds:
8.Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
Within 3 seconds:
9.Press LOCK button.
Within 40 seconds:
10.Repeat button procedure to program remaining remote transmitters.
SIDE NOTE: To exit programming mode: Open driver's door.
SIDE NOTE: A maximum of 4 remote transmitters can be programmed.
Hope this helps someone.
These are the instructions that worked for me (2008 Sport Edition)
After having failed multiple attempts at programming my keyless remote with the wrong directions this one worked like a charm (2008 Sport Edition). THANK YOU
Just got my 2 new Fobs in the mail and new keys.
Programed the Fobs in minutes and now need to get keys cut and program them.
I got them off ebay 2 Fobs and 2 master keys 33 dollars.
Will not go in programming mode for keyless
I still cant get into programming mode 2000 4runner. I look like a retard when trying this 1000 times? All videos ive watched show the lock indicater on side of door/orange tab, 2000 do not have this. Is there a hard reset on receiver?
Not sure what procedure you have tried but this is what I found for programming a 2000 4 Runner key fob...which is slightly different than what is posted for 2003 to 2005 4 Runners
http://www.toyota-4runner.org/3rd-gen-t4rs/7501-programming-instructions-keyless-entry-remote.html
" Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door. "
Awesome.
When
System malfunction.
How
Within 5 seconds:
Within 40 seconds:
Within 40 seconds:
Within 40 seconds:
Within 3 seconds:
Press LOCK button.
Within 40 seconds:
Perfect. Worked like a charm!
Key Fob Programming
I have a 2000 4Runner, and I too have felt like a retard, not being able to program my remote- so much for that college degree. I have tried both ways of programming (door shut and open and lock unlock repeatedly) to the letter, repeatedly, and none have worked! I spent 3 days taking it places (battery shop, locksmiths, techie friends, etc. NONE have worked for my 2000. Then I just put my old fob guts into a new case and went on.... for awhile. Now I am told my remote is dead, new batteries do not help, so I purchased a new one on ebay. No luck, revisit of the frustration. Do I really have to pay the Stealership the $70? Someone said in earlier post the they did not think the 2000 was programmable. Can anyone else confirm this? Why?
(Sorry for the non-politically correct term in first sentence, just frustrated and no other term fits as well)
You might want to post in the 3rd gen forums. The key fob programming for the 3rd gen might be different from the 4th...
You might also have maxed out the number of fobs keyed to the vehicle; I believe if it hits 5 it won’t allow any new fobs to link. I recently picked up 2 new fobs for my 2005 and my rig only permitted 1 to link up, leading me to think that some of the earlier fobs (which I don’t have) will need to be erased from the computer before programming new ones.
How can one erase from computer? At dealership?
