I
The beeper for all FACTORY systems (1999+) is on the passenger fenderwall back by the firewall. On those systems, it is the ONLY way you can tell by just looking. No control box exists, it is built into the Body ECU The beeper, I call it a chirper, Toyota calls it a Buzzer looks like this:
Ignore any answer that doesn't take into account what year you have and you don't give that. Post your year and I will tell you.
The pre-1999 years only had port or dealer add-on systems with alarms; there were NO factory systems. They vary by year.
http://www.toyotaparts.metro-toyota.com/WIRELESS_TRANSMITTER_&_PROGRAMMING_GUIDE_TS-EL010-07.pdf
OK, I have the chirper on my 99. How do I get a remote and program it?
Hmmmm?
:sadwave:
2001 Sport SR5, 3.4
Hmmmm?
:sadwave:
[MENTION=10169]TheDurk[/MENTION] Yeah I saw that thread before, where you have to stand on your left ear with the door open and kick your neighbor's dog while holding an apple between your legs. I may pop for the $30 remote, but I really want a remote start module like my 2000 has. I don't like aftermarket installers though, for obvious reasons, and I'm chock full of projects at the moment.
Thank you for the tip on the correct remote though. Waiting to see the progress on your frame swap! :director:
Mine has a sticker when I open the hood that says "this vehicle is equipped with keyless entry.blah blah battery disconnected blah." I just never received a remote when I bought it. : (
Look under the dash for the remote brain.
You should be able to get a remote for it if it's still there.
You might have to go to an installer to buy it and get it programmed.
After reading it again it actually says remote start as well. Any idea where to check for that
Under the dash. Drivers side.
Found it. Unplugged under the dash. Can I program any remote to these things or does it have to be the same brand.?
