Keyless remote - 2000 Limited - What're you buying...
rzgkane
Need to replace the keyless remote fob(s) on my kid's 2000 LE. What have you guys had good luck with? Are the abundant ebay options good? Should I stick with OEM? Are they even available?
Using the search will set you free!
More often than not what it does it piss me off and make me regret not posting a new thread to get quick information even if I run the risk of allowing an old timer telling me how my question has been asked and answered many times and I could have realized it had I only used the search function.
Whatever. Did I answer your question adequately?
No go for me
These are a no go for me (could be that I need a different remote since mine is an 02 SR5?). I did the programming multiple times just to be sure, I'm sending them back to the eBay seller.
My results as follows:
Lock button works fine after programming
Unlock never worked, even after multiple attempts to program. Sometimes the button seemed to do nothing, and even went sideways into a position where it was stuck almost. Didn't feel right at all.
The biggest issue of all of that based on my research... the Toyota alarm requires a keyless remote to open your door if it was previously locked with said remote the time before. So when I could only open with my key, the alarm kept going off.
Not sure what I did to finally clear that, but I finally got the alarm stopped and regained key unlock ability so I decided the keyless remotes aren't really worth the hassle to me after all.
seltzernator
