King Coilover Question
VernySanders
Hey all, I have a quick question aimed at anyone running the kings in the front and rear, if I purchase these shocks can I run them with the stock setup, or will I need aftermarket upper and lower control arms immediately before installation? Any input is appreciated, Thanks.
Typically the amount of lift will dictate if adjustable upper control arms are needed. In my experience, with around 2" lift I was able to get back into stock alignment specs but once installing my UCA's I noticed a increase in ride quality and stability.
LCA's should not be needed unless doing long travel or something of that sort. You might need to replace the lca bushings however as they tend to be a common wear point.
Front Kings have an 'extended travel' option that require upper control arms. If you get the standard length, they don't need upper control arms.
-Charlie
Crookedcat
