Knocking sound from rear cargo area???
Fadiddy said:
I recently started hearing this "knocking" sound from the rear cargo area of my T4R. It is not consistant, and happens when I hit certain bumps or potholes (not all), and sometimes when I turn. It sounds like a hanging object hitting a plastic panel once...if that helps...or even sounds like a rock when it bounces in the rear wheel-well, something like that. Just a "DTUCK!" I thought the noise was coming from underneath the car, so I checked the under carriage, but I didnt see any "loose" objects. Can anyone shed some light on what this noise may be, its driving me CRAZY!!!! Thanks!
Hi, I am fairly new here to this forum and just recently bought a 2005 4Runner Sport about 3 weeks ago. It has 18,000 plus miles on it and everything still looks and feels new. One of the things I have noticed in addition to some of the complaints other members have posted is this mysterious noise in the cargo area. I noticed this about second or third day of driving the car and I have'nt been able to find out exactly where it's coming from. It's not a big deal for me, but I will keep checking until I can find out what's causing it.
Fadiddy said:
okay cool...so just use grease or something? Also, is the sound you heard similar to what I was explaining? Thanks!
Glad that we think we figured out how to tell what part it is. I think we're also talking about the same noise -- at least I hope so, because then you know how to fix it. The tech at the dealership just uses regular grease on it. Seems to last 1,000-2,000 miles then the noise starts up again.
I know....im gonna try some grease on it, and see how that works...i have a feeling your right about that, cuz it sounds like its almost coming from inside the lift hatch. I'll try it and post the results. Thanks John!
I just bought my 4runner today and while driving it back from the dealer I noticed a knocking noise from the back. It didnt take me long to realize it was the cheap plastic license plate holder the dealer stuck on it flapping against the rear hatch. Simple but loud and annoying.
I thought that too....yet, i replaced the license plate holder with a new one and used cushion tape to prevent flapping and other noises. For me, its definitley not the license plate holder, although i did have that first.
I had a similar problem a while back. It ended up being the spare, it wasn't cranked up tight enough to the frame so when I turned or hit a big bump I'd get a knocking sound in the back. Tighten the spare up to the frame and problem solved.
Oh yeah, I should check that....I always thought about it, but never gave it a shot. Thanks!
I noticed it knocks (from the rear passenger side) when making tight right turns (like turning into parking stalls).
I made it go away for a little while by unlatching the rear seat, then slamming in back into place, but it would come back after a couple of days...never did get around to really looking into the cause though.
I also noticed the passenger side of the front bumper cover is a little loose...my runner only has about 2k miles on it...I hope this isn't an indication of Toyota build quality going bad...
I have an 03 and a rubber stop for the rear window glass came lose in my rear hatch. It would rattle and roll on bumps and such. Noticed it one day closing the rear hatch. Just where i found it.
SAA
Try wrapping a layer or two of electrical tape around the anchoring loop. For many of us here who have the rear seat squeak, the tape method got rid of the squeak. There is a TSB out for the dealer to enlarge the screw holes on the anchor loop and adjust it so it doesn't squeak. I rather not waste an hour or so of my time for them to do the fix when a minute is all it took with tape.
Okay....so I take my car to the dealership today and had them check out two things:
1) The "knocking noise" from cargo
2) The sulfur smell when accelerating (which i dont care what anybody says, should not appear even if using shitty gas).
Here is what happened:
The service manager came with me to replicate the problem. The first few minutes....not a peep came out. I mean the car sounded like a you were sitting in a Lexus LS430. Then, "DTUCK!" Yup, we both heard it, and again, and again, and again. What was funny was it happened whenever the car felt like making it happen. We tried hitting potholes, taking sharp turns, etc... it only happened once in a while, but we had an idea when the sound would be coming upon certain uphill driveway climbs, sudden turns, etc... Well, when we returned to the dealership, they put the car on a lift, and looked underneath. The mechanic found something unusual. The muffler seemed to have a fresh "bare" metal scrap, almost as if it was rubbing on another metal. So, he called me over, and had me sit in the car while lifted (this was a drive up lift, so it was safe). He began moving the muffler and making it hit where metal was scrapping it. He asked if the noise was the same...and, it kinda sounded like it, but not really. So, we checked everything; spare tire, rubber stoppers, rear cargo cover, plastic panels, etc...and couldnt determine anything. The guys at the dealership got stumped on this one. So, the service manager said, "since i heard the noise, and we were able to replicate the problem....we know there is a problem...and we know it can be fixed!" So, the dealership told me to bring the car back on Tuesday to have it looked at overnight and to be driven while someone sits in the back to find out where the problem is exactly....plus, I get the same car as a free rental until they resolve my problem...GREAT SERVICE!
Now, the Sulfur smell, is a known issue...especially with 03'-04' T4R...and the service manager said, "cheap gas has nothing to due with it!" He said the reason for the Sulfur stink is due to some catalytic converters made in Japan, and some outsourced to Japan, and something about ECU logic programming, i dunno...it kinda made scense though. So, he said, if we get it to make the smell again, you'll get the latest revision of the U.S. emissions spec catalytic converter and assembly. Sweet!
Overall, Im gonna get to the bottom of this, and hopefully make this a sticky when resolved cuz I know alot of you are having the same freaken problems!...otherwise...:bash:
* * * UPDATE * * *
The knocking sound ended up being the rear right hatch shock. The shock just needed adjusting, and it solved the problem. If anyone is having this problem, check the rear hatch shocks!
* * * UPDATE * * *
I know this is from 6 years ago, but I am having the exact same rear cargo area/hatch area hollow "DUNK" and it is freaking driving me insane. I had my local mechanic look at it and sure enough, he drove it and couldn't find anything.
I am going to try and duct taping over the rear seat retaining D-rings. I will grease the bump stops of the rear hatch also. Can you please elaborate on the hatch shocks needing adjustment? What kind of adjustment??
Well my issue turned out to be a heat shield ABOVE the muffler. It had rotted and slid off the bolt. A couple of washers and its back in place.
