Konig Countersteer X w/stock tires/no lift...pix?
You when you do it ! :)
Joking but if you think it's right then go for it man.
Will want to see pics when it's done.
Be careful what you wish for. :tongue1:
Any one got photos of the above combo?
Please?
Running those X's with stock tires and you'll most likely increase gas mileage as they are almost 10lbs lighter per wheel then a stock wheel.They are the lightest 17" wheel made to fit our 4runners and they will also move the wheels outward .90" outward giving it a more aggressive stance.A whole bunch of us on here are running them.
Harper,
What were your reasons for running the X's vs. the six shooters? Is one better than the other in your opinion?
Excellent, thanks...looks whimpy compared to the guys with Duratecs, but I think I will wear out my stock tires, then go for the lift/bigger tires.
Does the bigger rolling circumference of the 285's screw with the speedometer, climb control or any sensors related to wheel speed?
Does the extra offset of the Countersteer X make the wheel/tire "stick-out" at all ? If you look at the vehicle from the front or back, is the wheel proud of the fender at the top of the wheel opening?
Harper,
Harper bought his set before I had my set. The six shooters are fairly new, they weren't out when we both had our sets.
Its all just preference. The six shooters are 17x9 0 offset, the X's are 17x8 -10 offset.
More pics for you. My 4runner has 5100s all around, but is at the stock rear ride height, and about 1 1/2" raised in the front, to get it approximately level.
Tires are 265/70 17 Bridgestone Dueler Revo II's.
1engineer: Thanks, I've been lerking around but have been too busy to be active on fourms.
SShink: harper7 is correct. with my step up (see Sig) I'm running 2-3mpg better then stock. Yes they are way wimpy but Im planning to ware down my stock rubber then go to the Duratecs as well.
"Does the bigger rolling circumference of the 285's screw with the speedometer, climb control or any sensors related to wheel speed?"
- Yes, but its not going to break anything. Use this tool to see rotation differances to minimize drastic changes.
Finally got mine on...
The difference in acceleration from a stop and stopping distance is quite noticeable.
Very nice touch! What else do you have planned? :eyebrows:
Btw, I can't tell but did you change tires as well? And do you mean it accelerates and stops better because of the lighter weight?
They're stock...I wanted to do an experiment in performance gain by taking 10 pounds off each wheel. I do plan to change the tires when these wear down a bit, maybe this fall. The stock Dunlop AT20's slip and slide in the snow...hoping winter ends soon.
There is a noticeable gain in acceleration from a dead stop and a shorter stopping distance. I assume this will definitely increase city gas mileage.
I am a proponent of not messing with factory engineering, so I will probably not lift it or run larger diameter tires. I do have ShrockWorks sliders ordered and am going to black-out the chrome emblems (mask or remove emblems, self etching primer, SEM trim black) when it's not freezing out. Other than that, I am just going to drive it mostly on the road and off in the Adirondacks.
youngrk
