I went up one size - to a 275 70 R17 in the BFG AT TA KO, and no problems with rubbing at all. I think on the TE you can probably go two sizes, to a 285, but I don't know anyone that's done it yet.I am really wanting to upgrade my tires but i dont want them to rub. Anyone know what the biggest tire on the stock Trail Edition Rims are without rubbing
Thanks.
275/70/17 which is up 1 sizeI am really wanting to upgrade my tires but i dont want them to rub. Anyone know what the biggest tire on the stock Trail Edition Rims are without rubbing
Thanks.
Do these larger tires affect the speedo? What is everyone doing to compensate for it?
285's will rub.
Yes,Going up one size bigger then a stock 265/70/17 to a 275/70/17 affects speedo at 1.75% too slow. In other words ,when your speedometer reads 60mph you are actually going 58.9mph. When it reads 100mph you are actually going 98.25mph. I found this out here.Tire Size Calculator - tire & wheel plus sizing
Nothing you can do really,except figure it out in your head.
Thanks.
Here's a link with pics of the clearance I have with the 275's.
http://www.toyota-4runner.org/5th-g...1022-show-all-photos-upgraded-tires-here.html
Harp, you have that flopped. A larger diameter = the speedo reading lower than you're actually going. For each revolution of the wheel, you are covering more ground w/ a larger diameter tire. Most speedos are a little on the conservative side from the factory, though, so you should be pretty spot on after a slight upsize.
The only difference in the SR5/Limited and the TE fender wells is the front inner fender well on TE is 4 inches shorter in the front. It will probably rub higher then that when you have wheel compression with the wheels cut with 285's,like when you encounter a bump on a curve.You will still need to trim plastic for 285's to not rub. Wider aftermarket wheels would make the tire smaller,not bigger.I have a feeling 285/70/70 will fit.... Looking at the pics from LWN with his 275's. A member here put 285s on and the tire shop said they rubbed. BUT he had aftermarket wheels. Not sure if they had different backspacing or not... No one to my knowledge has tried 285s on Stock TE wheels.
Dude, harper, I got you thinking about the KM2's! By the way, my TE is ready to go to pick up from the dealer, with KM2's on it (Only LT265's), I'm just waiting to see the incentives for March. I'll have pics soon.
Thanks for the info Harper. Well researched. I'm liking the Toyo Open Country MT's I have read a ton of reviews on them. Everyone likes them and says they are very quiet. They look great only downfall is the weight. I still would like to see the 275 GY MT/R on the 4Runner. Not so sure about the white letter outline, or how it will do on pavement
I have the 275 GY MT/R on the 4Runner on mine and am loving them. The noise is a very low hum (which I kind of like) and I am getting around 18 mpg with a mix of highway and city driving. - I will post pics today! Promise!:reddance:
No rubbing ?Here are pics of my 17" Black Moto Metals with Wrangler MT/R's W/ Kevlar 275/70/17's
I have taken them through the snow and large puddles =) They have handled very well. I was told to get them siped, as that will help with icey conditions.
They look amazing. Can you give us some feeback on the MTR's.
How loud?
How do they do on highway and pavement?
Whats gas mileage like?
Do they ride rough?
Didn't you have the duratracs for a bit? how do these compare if you did
thanks
No rubbing ?
A little info on the Moto Metal rims please.
They fill out the wheel wells more and make the 275's look bigger.
They do look Sweet!
What is the Moto metal rim part numbers?
I'm not going to get these same ones ,just the fit info.
What width did you get? 8 inch or a 9 inch?
What offset ? stock is 4.5 inches
I take it you had to buy a new set of conical lug bolts since these are lug centric instead of the factory hub centric rims or did you get hub rings?
Do Tell![]()
