largest tires?
OtrRunner
i will be running a sonoran steel 1.2 lift with a 4crawler 3" body lift on a 3rd gen and 15x8 rims are 35x12.50/r15 the largest i can run?
WOW that is a huge lift and yes that is the largest you can run. I have the 1.2 rear and CO's up front and run 33's no body lift, and I feel tippy at times since we are already top heavy. You can fit 35's with a 1.5 in BL and some minor trimming. Sonoran Steels website has a good write up of this information. Also 35x12.50's? I know they make that size in a 15" and 17" rim size. If you have factory 16" you wont be able to fit a 15" rim over the brakes.
You can run a larger tire, but you're going to have enough problems trying to squeeze 35's on.
What gear ratio are you changing to so you can turn those 35's?
i will be changing to either a 5.29 or 4.88 not real sure yet now i am running a 3.96 (i think its a stock sr5 gear) with 31s
Tx470
