Last questions about a lift...ordering today!
auxiliary
Ok, I am planning on ordering a lift today and have decided to go ahead and get the complete OME kit from Toytec.
I hope to get an ARB front bumper....one day. Not sure when that will happen but it's in the idea realm. Should I go ahead and get the medium coils instead of the regular one? Also, if I get the medium coils in the rear (Hopefully so I don't sag under load), will that drastically hurt the ride quality?
Also, with the front spacer plate..I will sit level? The main thing I fear is doing a lift and STILL having rear sag.
Finally, I have 267/75 tires. Will my car look silly?
Here's a picture for notes.
If you go with medium coils you shouldn't need a spacer plate.. If you're going with the softer coils you will. meduim coils will ride stiffer.
You will still have very slight sag when the rear coils break in. I do believe toytec sells some rear coil spacers to help with this problem that I may use myself.
I don't think it would be that bad looking
yes i would recommend going with the medium coils up front if you are planning on getting the ARB. in the meantime, yeah the ride will be a bit rougher than the standard ones but its not going to be a horrible ride. i would still go with those because there is more of a chance that the front will sag when you put the bumper on if you stick with the s****ard coils.
as for the rear, the OME either the 890's or the 891's will work fine. i think that the 891's will have less of a chance of sagging and you can carry more weight too. however, the 891's obviously will be a bit rougher. both the 890 and the 891 area a 3 inch spring but most people have said that you get a 1/2 inch more with the 891. i would recommend going with the 891's if you really don't want sag
i sent you a discount code :thumb3:
yes get the diff drop
nice runner BTW :cheers:
Thanks! I've had the window's tinted since the picture. My drive way has a downhill slant so you can't see the rear sag.
Ok ordering:
OME Complete
Medium Front Coils
891 Rear Coils
NO Front space
Front Diff Drop
Fronts unassembled.
Regular shipping with discount code (Thanks!) $757 To my door!
It was either this or an iPad....hope I made the right decision :trophy:
Ok ordering:
OME Complete
Medium Front Coils
891 Rear Coils
NO Front space
Front Diff Drop
Fronts unassembled.
It was either this or an POONPAD....hope I made the right decision :trophy:
You sir made the correct decision;):
sweet! i think everything is in stock so it should ship out either today or tomorrow.
post up the pics when you are done!
I'd be your BFF if you can get everything shipped out today..
I mean it's what, 9 there?
I'll try to get a before/during/after picture thread going too.
