LAVA Cable Instrument & Patch Cables - Custom/Made-to-Order
FatTiresRollin
I currently have some bulk cabling materials in stock and I am offering made-to-order high end instrument cables and patch cables. Pricing varies based on cable/plug type and length. All cables are handmade to order by myself. I will always "warranty" any cable from any obvious manufacturing defect. If there happens to be an issue with shorting right out of the box, then I will gladly replace your cable immediately, no charge. I am also offering to repair any cable for as long as you can remember my contact info (Lifetime). This statement of course has its limits, but we can discuss details if you like before finalizing your order.
I have limited materials in stock, so first come - first serve. All-In-All, I have about 100' of each type of instrument cable, 20' of black patch cable and 20' of blue patch cable. I have enough plugs to make 10 "BEST" cables, 5 "BETTER" cables, 5 "BUDGET" cables and about 20 patch cables.
Here are the materials and some pricing examples: I charge a flat $5 for shipping...FREE SHIPPING if you buy at least 2 instrument cables or 5 patch cables.
GOOD/BUDGET Cables: LAVA Magma Cable, G&H standard nickel plugs - straight to right angle, Black heat shrink. ($22 For 10' Cable)
BETTER Cables: LAVA Magma Cable, G&H high clarity nickel straight plug to G&H silent series right angle plug, blue heat shrink. ($24 For 10' Cable)
BEST/Premium Cables: LAVA ELC Cable, G&H black & gold high clarity straight plug to G&H black and gold silent series right angle plug, Orange heat shrink. ($42 For 10' Cable)
Patch Cables: LAVA Mini-ELC Cable (Black or Light Blue), Lava 229 Pancake right angle nickel plug. ($10 for 3"-6" cable)
LAVA ELC Cable: The original cable that started it all! This cable is specifically designed to be flexible, rugged and provide superior, balanced sonic characteristics that enhance the sound of any guitar it is plugged into. It features a larger outer diameter of .305", 99.99% Pure Oxygen Free Copper (OFC) for both conductor and shield, and capacitance of 28 pF per foot that is in the sweet spot range for instrument cables. Every aspect of this cable was designed with the guitar player in mind to provide for low microphonics, reliability, and superior frequency response.
LAVA Magma: With better sonic characteristics and performance than all instrument cables in its class, it Features a 99.9% pure copper low strand count conductor, 29.5 pF/ft low capacitance and a 93% spiral shield for excellent RF rejection
LAVA Mini-ELC Cable: The cable is specifically designed as a patch cable. It features 99.99% Pure Oxygen Free Copper (OFC) for both conductor and its 98% braided shield and has capacitance of 28 pF per foot that is in the sweet spot range for instrument cables. With small outer diameter of .195" it is extremely flexible and ideal as a DIY cable for pedal boards and racks.
LAVA 229 Plug: Lava Cable has partnered with Switchcraft to introduce next generation pancake-style plug the Lava 229™! Improving on the "original" and popular Switchcraft 228 plug, the Lava 229™ plug features two plated copper alloy solder contacts and a Mylar shorting protector along with a single piece tip and rod assembly for greater strength and reliability. The Lava 229™ plug has a body width of only .425" and a capacitance is just 8 pF. The best has just got better. . . Proudly imported from Chicago! Made In USA.
G&H Plug:
The Quiet Plug™. Would you like to be able to switch instruments without running to the amplifier? Our unique design with its spring loaded ground sleeve, creates a more reliable switching plug, with a 1/2 inch profile that fits your guitar.
The patented RF2P design was the First 1/2" profile Right Angle plug. The First Right Angle plug to work in dense jack fields (5/8" centers). It's the one that eliminated the hassle of soldering to a large steel body and the first to do away with the screws.
operation.
"Look for the Copper Tip."
charlesz
