Lazy troubleshooting question.
Evil Ash
01 runner with 120k I have owned for 2 months
I will be lazy and ask the forum of knowledge before digging into the front end.
It has a "chirping" sound coming from what I believe is the drivers front.
The noise is most prevalent at low speeds with poor road conditions (most roads in portland :wink2: )
A good pothole and I don't think it makes the noise but just jostling of a poor road and its chirping like a bird.
It also has related or not a decent vibration at ~62mph that a balance didnt correct. (may have been a poor try by the tire shop)
Moving sounds are my favorite to troubleshoot (sarcasm)
any idea to start with would be great.
thanks
Squeaking could be sway bar bushings. Vibrations could be alignment, tires need balancing, worn bushings, etc. Jack it up and do the ol' push pull test.
Kurtis
Lazy troubleshooting advice...
.......... and ......... if that doesn't work then you might ..................
Hope this helps.
Squeaky body mounts/bushings?
Kurtis
Thanks Hacker and Kurtis
My guess on the vibration at that specific mph is a U-joint.
BlackCat914 is it posible to have a bad u-joint and only get the vibration ~70% of the time im in the 60mph range?
You should get the vibration more when you accelerate if it's a bad U joint.
Ill double check on the way to work in the am.
if I remember correctly it vibrates under acceleration, and while cruising but I cant remember if it vibrates while deceleration.
I think the truck sat for 4 months before I bought it. I just noticed the oil change sticker in the window say 7/17/12 or 124k I bought it early August with 119k. flat spot on tires? not sure if thats real.
Ill update from work in the morning.
Flat spots in tires are real but only last a couple minutes and is more prevalent in colder temperatures. Bias ply tires hold flat spots long as well. I am assuming you don't have bias ply tires though.
Toyo open country A/T dont think they are bias ply.
Aaayh!
it vibrates on the deceleration also. only in the low 60's.
A u-joint does not usually only vibrate on acceleration contrary to what the other poster said. Your chirping noise might also be the same ujoint as well. Typically, ujoints squeak or make a rotational chirping noise at slower speeds, many times when under opposite load as usual, like when in reverse. Does the vibration seem to get slightly worse when decelerating? Does it seem like a very fast vibration where it almost turns into a humming noise at higher speeds? Sorry for the grammatical errors, I'm on my phone.
the chirping is directly tied to the quality of the road. It chirps a lot if the road is in need of refinishing and not at all if its smooth.
vibration seems the same accelerating/cruising/deceleration in the ~62+
I havent topped 70 so I dont know if it dropps off.
If there is a noise to the vibration I cant hear it over the road noise.
Ah, I just had a rear U-joint go bad and it vibrated so badly that it turned into a humming noise. It was also associated with a rotational chirping noise.
mine had a chirping squeaking noise from the drivers area and found out it is the drivers seat bolt the front left one nut actually had broke free from the surrounding area not sure if that is your issue but it was driving me crazy until i found it
Exactly right, when my U joint when bad it chirped like a bird, it was the oddest noise
thanks
Your wink scares the **** out of me. I would point to your U-joint if I were local.
Change it out! You could oil it first to see how it changes in sounds. If nothing sounds different, give it a tug and see how it sounds. Things get squirrely when the U-joint gives out..
I meant you should notice the vibration more when accelerating/decelerating as opposed to cruising.
seltzernator
