Lc wheel rub with brake caliper???
achha64
Hi,
I just installed the LC wheels last week run it for a week now. But now the caliper rub with the wheels. Did I need to know that lc wheels need spacers? Or I'm the only guys that have this problem?
I'm running 265/70
Hi,
I'm running 265/70
Did you run them for a week with no rubbing until now?
No rub at all. Until today and only the passenger side. The passenger is the side that my wheel bearing start to worn out also. Can this cause the rub?
This rub noise come only when I turn the steering wheel more than 1 round
Basically I heard a grinding noise when I turn
The caliper and wheel is solid. If it was not rubbing and now it is than something may have loosened. I would check all bolts and make sure your lugs are tight.
I just check all the bolts and tight all the lugs! But based on a full night of research and video search I have only have two more possible culprit:
- The back brake plate
- Wheel bearing (this one start to worn out already)
