Le power of ze steering
3rd gen king
When I turn ALL the way, it makes a loud noise! Like the regular "max out sound" but a lot louder. I had all my pumps and pullies everything off Sunday and do y'all think it got messed up by me taking it off?
I'm in class right now, but il upload a vid when I get home.
I'm just looking for some input..... Guys, thanks
And I know i shouldn't be maxing it out, it was an single incident but I noticed it.
Could be some air in the PS system still. Work out the air and make sure the ATF level is correct in the reservoir.
Fill it up, jack up front end, crank car and turn wheel from stop to stop about 15 times. let set for 15-20 mins. Repeat as necessary until all noises are gone!
Your threads crack me up! lol! ;)
Haha why's that?
I CAN'T A FUCJING BREAK!!!!!
MY spindle??? The thing sammiched between the upper and lower ball joints POPPED ITS ASS OUT WHILE I WAS DRIVING! Luckily I was pulling up to an intersection (litteraly going 5mph)
:toilet: this same side has happened 2 times in 2 years.
Wrecker was 120
Brake lines busted and cv is bent and all this other poop /:
I so wanted to cry... I even had to do flipper hands to hold it back.
Haha why's that?
Wrecker was 120
Broken lower ball joint?
Also...CV? Don't you have a 2wd?
He ran over a lowly 4wd Jeep and absorbed it's powers. He now has the power of a Toyota and the 4wd of the badest 4wd drivetrain known to man. I then it pooped out on him. Bad heep, bad heep! Karma is a beach! J/k Pulling your chain. It really sucks that you just got the cooling system fixed and now this. I think it will work out for you, I am glad it happened @ intersection instead on the open road. Good luck!
Yeah, I am pretty lost too. This happened today?
If you are 2wd then you don't have a CV, you must have meant UCA. Lots of pictures of LBJ failures. Check them out. Be very glad it happened when you were going slow.
and 2x in 2 years? What the hell are you doing to it? What brand LBJ did you use last time, because it sounds like it was total crap, and seriously unsafe; like, sue the manufacturer unsafe.
RACK AND PINION, sorry I kept calling it the cv.... -.-
And the p.o. (my best friends dad) didn't bother with turning a wrench do everything was done by a shop, but yes this will be the second time in 2 years
WHAT BRAND IS SUGGESTED GUYS?
Philthyphilthy
