I am leaking fluid where the tranny bolts to the engine block. Do you think there is any chance that a couple of the bolts came loose, or would it be an expensive re-gasket job at the dealership?
It doesn't look bad in the pictures, but it's making a mess on my driveway. Its dripping, not just seaping.
Any thoughts on a fix?
Correct me if I am wrong here. But according to this picture, there normally isn't any fluid in contact where the transmission bolts to the engine block? (If the vehicle is parked and the engine off)
Are you sure it is transmission fluid and not coolant? Toyota antifreeze is red/pink in color.
It is infact antifreeze (taste test never lies! lol) I need to trace it back to see where exactly it's leaking from. That's a little relief, as coolant is easier to add and see when it is low.
How many miles? Water pump is good to about 90k
About 67,000 miles on my 2004. You think that if the water pump seal is leaking it would track all the way back to that point?
And yes SkylineGTRracer, that is a relief that it is coolant rather than tranny fluid leaking. I would hate to see that repair bill at the dealership. I still hope it is nothing major!! *fingers crossed*
Are there coolant lines under the intake heating the throttle body? Any leak on top of the engine will tend to flow down to that point. The engine itself will be warm enough to evaporate the coolant, but that area is cooler and the coolant will collect there. A hose is most likely, but some are pretty hard to get to on modern engines.
