Leaking tranny fluid: Need advise
I might have to give that a shot. It's a pretty serious leak, so hopefully it isn't too hard to find the source.
The basic way mechanics look for cooling system leaks that are not obvious is to use use a "Cooling System Pressure Tester". The tester is attached to the radiator in place of your radiator cap. You manually pump up the tester to pressurize the cooling system and then look for leaks.
