Leaking Tranny
tucktuck8
I pulled up to my house and noticed a pretty good sized leak underneath. It seems to be tranny fluid and its coming from the transmission bellhouse. Is there a gasket that I could change or is this bigger than I'm thinking?
if it is truly coming from inside the bellhousing, then it is likely a front pump seal.
at minimum, the transmission has to come out to fix it.
Ugh, Okay I will take it to a tranmission shop to have them inspect it. Thank you guys. Is this a pretty common problem with these transmissions or did I just get a bad egg?
Could also be a leaking torque converter. Double check that the leakage isn't coming from the top. I had a truck that made it look like fluid was coming from the bellhousing, but it was fluid from the valley up top of the motor.
Tx470
