Leaky front boots on cv axles after 3 in lift
Kevin420
Hey everyone, any advice on doing this right the first time? Should i go ahead and do both axles, or just boots. They do not click or anything, and what happens if they brake while driving? thanks
Inspect the boots for tears, if they are not torn you can replace the stock ring clamps with hose clamps to get a tighter seat.
This is common on lifts at 3+"s and is not necessarily a sign of bad CV's or failing CV's. The grease is just being forced out due to the new geometry.
But again inspect the boots well, if there is a tear replace the torn boot. I would personally do both since it is off the truck and all four if you have a tear on each side.
utkrstam
