leaning on the right
SMSmitty
My 87 seems to be leaning/sagging to the right front, I'm not quite sure why. i have new shocks, and the tires are inflated properly. Any ideas?:shrug:
thanks, SMSmitty
Shocks dont effect ride height.
If they are the original torsion bars, chances are they are tired and should probably be replaced
You can try turning the right one up a bit to get it even (or the left one down). Get a factory service manual, or chiltons manual, theyll tell you how to do all that. Or if your google-fu is any good, there are tons of write ups all over the internet on how to do it.
Measure from the top of the rim to the bottom of the fender on both sides, that will tell you exactly how much its sagging.
The right side is known to sag more, thats the side gas tank is on.
Edit: Its a slow day at work, found one for you. http://www.off-road.com/trucks-4x4/torsion-bar-adjustment-19258.html
first park it somewhere flat and measure it.
front and rear.
it could be as said above, just weak TBs'. but you could also have a broken rear spring.
seltzernator
