LED Dash light Problems
The Jc2203
So I changed my guage cluster out with all new LEDs and it worked just fine, so I decided I was going to change my HVAC out also so today I pulled the bulbs and put new ones in and now neither the HVAC or mph/rpm will light up. My O/D blinkers seatbelt etc... will still light up I'm not sure what the problem is I checked the fuses and nothing was blown, dimmer light is fine and everything is plugged in. 98 sr5 btw
anything else not working? dome, radio, etc?
i know you said you checked fuses but there is also fuses in the engine room. Check the Dome fuse for sure.
+1 this.
I've managed to short the Dome fuse in the engine box a couple of times mucking around with lights and wiring. Symptoms were exactly as you describe.
PRWhite
