LED Flasher Relay
sam.basye
Member
I repurposed my turn signals into shoulder lights and relocated the front turn signals to the filler plates below the headlights.
Each front signal is 6 x 9w amber LED's utilizing the stock turn signal wiring.
Rear turn signals are stock incandescent bulbs.
Left and right signals hyper flash, but hazards flash normally.
I bought a Novita EP35 LED flasher relay and it only made it worse. Left and right signals and hazards all hyper flash. Argh!
Specs:
3 x 27w + 5w
6 x 27w
Max 6 lamps
What's the next step and why it no worky?!?!
A load resistor for each side?
I retrofitted 7443 bulbs from a OEM tail/brake housing.
Updating my headlights soon, and will be swapping these out for the '99+ corners. Therefore, this set is for sale.
Got it all straightened out with the part suggested by Tyler James Inc. Thanks again!
I was starting to get used to the fast clicking. Now that it clicks at a normal pace, it seems slow. Haha
No more looking like mall security!
They bright
Since it's a dual filament bulb, how did you wire it up?
Just saw this, I'm sorry.
It has a ground, and then the green(tail) splices into the park hot(green), and the green/black(brake) splices into the signal hot(green/yellow?).
Don't quote me on those colors, my memory on that is a hair foggy.
Edit-
Found a pic-
The grounds being spliced together is redundant, but I just decided to do it that way.
Looks like my color-guessing was a bit off, but you can see the signal is green/black, and is spliced with the brake(green/white).
Edit-
Found a pic-
It's all good. I like the concept.
I kinda want my LED's to act as both DRL's and turn signals, but think it will be more work than I'm willing to put forth. Lol
Laredotx
