LED interior mod 96-98
t4r4life
Elite Member
this is the intereior led swap mod for 1996-98 4runners, lights include maps lights dome light and cargo light
first map lights, take off the little plastic clip where my finger is, a sharp knife is best but a skinny flat head will work too
IMAG0233.jpg~original
then use your finger pull toward you the cover will pop off
IMAG0235.jpg~original
this is the inside, take off the stock bulbs carefully, dont push the bulbs into the plastic pull down while using a knife to push back the metal clips
IMAG0236.jpg~original
dome light, using a knife to pop open the cover the bulb is right under
IMAG0237.jpg~original
cargo light, there is a small notch just big enough for a tip of a knife, insert knift and carefully pry open the cover
IMAG0238.jpg~original
all 4 bulbs are the same 30 mm
IMAG0239.jpg~original
you can find led replacement on ebay for cheap, they do ship from china so expect to wait a long time.
Car Interior Dome 12 SMD LED Festoon Bulb Light 31mm - eBay (item 220760272223 end time Apr-24-11 17:53:03 PDT)
Total cost of mod: 8.87 dollars
Does changing the map lights out make a big difference? I would like to see a before and after shot of just those lights.
Hopefully you guys already knew how to change the bulbs in your trucks. If not, you have some acquainting to do.
I upgraded in the 99 interior with the 25 LED superflux ozniums. It's like the sun in my 4Runner :) Both map lights and both dome lights.
Works in the pre99 dome lights if you want. Takes some cutting and such, but if you have basic competence, you should be able to do this.
Oznium LEDs in the map lights must be insane. Which one did you go with COB?
I have the 25 in my dome light and that sucker is bright.
MMJR_T4R
