Led light hyper flash
Coastal417
Just thought it would be supper spiffy to install leds into my little beasty, now they have the hyper flash problem. Read several dozen threads about manipulating the resistors, adding resistors, or on some 88-89 models cutting that resistor out completely so that it is not sensitive to the change in resistance from the LED. Im at a loss, not sure how to fix hyper blinking, but dont want to give up pretty new leds.
Jacalyn
too hot?
I see them on amazon as well....it says they get hot and can not mount to plastic.... do you have any problems with them getting to hot?
....I don't know... Not so hot that they have ever caused a problem. You can use your old turn signal lights as a load dampener and just hook them up somewhere hidden
