Led low beam with halogen high?
K9trainer
I need to up grade at least my low beam headlights 2015 4Runner, I just can’t see at night.
For now can I just add led low’s and keep the stock high beams?
I’ll finish the conversion later.
Doing just the low beams is perfectly okay. I have the Morimoto 2Stroke LEDs for low beams and I’m not impressed. The general consensus is that HIDs are much better than LEDs just don’t go too blue (5k or 4.3/4.5k should work best for output).
Although, I did but some generic LEDs i got for free in my high beams and they are ridiculous. They put out almost as much light as my 30” LED light bar.
I’ll check Monday If HID are legal in Hawaii or if I’ll need to do a recon inspection.
PIA here in Hawaii
Here is what I found for Hawaii::
“Is a reconstructed vehicle permit required if only aftermarket headlight or taillight assemblies are installed on my vehicle?
If the only modification to the vehicle is replacement headlights or taillights, a reconstructed vehicle inspection or permit is not necessary.
Aftermarket lighting equipment installed on vehicles must be U.S. DOT approved and of correct colors; white for headlights and red for taillights.
Vehicles 1968 and newer require U.S. DOT approved side marker lights/ reflectors on the sides and must be of correct colors; amber on the front and red on the rear.
Aftermarket High Intensity Discharge (HID) headlights are prohibited unless U.S. DOT approved for the vehicle installed upon.”
Are any of the HID dot approved?
Since they are already projector headlights, I would say It’s just a bulb replacement. The only modification you need to do is drill a hole in the dust covers to pass the ballast wires through.
You could always just put the old bulbs in for inspections right?
PIA here in Hawaii
No. There are no aftermarket lighting options that meet the FMVSS.
While DOT does not "approve" anything, a manufacturer of aftermarket gear must certify that their product meets ALL of the requirements of the FMVSS.
A note about the usual comment that "it is a projector housing so it is OK". That doesn't hold water either legally or in practice. Each bulb design (halogen, HID and LED) is different and requires its own housing design.
I too had the 2stroke 2.0s but I was content with them except for rain. In rain the 2.0 are about the same as stock halogen. The stock halogens were terrible and I tried a few halogen upgrades like brighter H11 and H9 mod but not happy with the "look" of halogen. I have since upgraded to the latest and greatest GTR Lighting Ultra 2 and they are definitely brighter than the 2stroke 2.0 but have not tried in rain yet.
2015 Toyota 4Runner Low Beam High Beam Headlight
2015 Toyota 4Runner Low Beam Headlight H11
Boslla Bullet B4 H11 H8 H9 LED Headlight Bulb Fog Light Bulb - The World's First 4 Color LED Headlight
2015 Toyota 4Runner High Beam Headlight 9005
Boslla Bullet B4 9005/HB3 LED Headlight Bulb - The World's First 4 Color LED Headlight
2015 Toyota 4Runner Front Fog Light H11
Driving visibility has been greatly improved after installing the Boslla B4 led headlight bulbs. They have 6500k/4300k/3000k three color temperatures, work perfectly for rainy, snowy, foggy, and more extreme weather conditions.
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 6500k
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 4300k
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 3000k
I’ve done the exact thing.. not worried too much about high beams, I will get to it but no rush!
The best bang for your buck to improve your headlights is to keep a halogen bulb. Check out this comparison:
3rd Gen HID vs LED vs Halogen H11 projector headlights | Tacoma World
And more reading about why your LEDs are not helping:
Why Most LED Headlight Upgrades Don't Really Work: An Expert Explains
That’s the crazy thing about changing it up or modding MY car, if I like something for the sole reason of LIKING it, or choosing what I WANT on MY truck, Then I’ll be happy no matter what in the end... regardless of the scientific reasoning against it or graphs and charts PRO halogen, if I did things that way and listened to everyone else’s OPINIONS or Reasons as to why I should and shouldn’t then it wouldn’t be MY build.. I LOVE MY LEDS ON MY TRUCK :)
I think you’re taking their comment a little too personal. They just simply posted up some comparisons saying it was something to check out not that you personally made a mistake and should change what you’re happy with.
The chart is pro halogen because currently with the 5th Gen housings, a performance halogen seems to work better than an LED. When LED technology catches up and advances I’m sure that’ll be a different story.
I’ve run 4 different sets of LED lows on mine and either hated the output in certain conditions, or the beam pattern was lacking. I’m also not a fan of night driving as I’m very light sensitive. I ended up with the H9 conversion which has kept me pretty happy for the time being.
It’s you’re truck, do your thing man. If LEDs do everything you want and need, awesome I’m glad. So many people swear by HIDs too... I’ve tried those and disliked them as well haha
That TacomaWorld thread does recommend one LED bulb, the Hikaris:
"The best performing replacement LEDs by far are the Hikari Ultras covered in this post, which have better focus and output intensity than the competition. They are the only replacement LEDs I would recommend. Note they are outperformed by the best halogen performance upgrades."
I installed the Hikari Ultra LEDs in my 2015 TEP and am really happy with them. I shared how to get them into the housing without too much hassle in this thread.
Have any way to verify that claim? :doh:
Here's a pretty scathing review of Boslla LED headlights, which falls in line with pretty much every other LED headlight bulb I've seen tested.
Kickstarter Thoughts? | Page 2 | Tacoma World
Our first-generation product was launched in 2018. In the early stage, we did have some shortcomings.
Thank you for all the suggestions and feedback. In the past two years, we have continuously improved our products to better adapt to technical specifications and driving safety.
There is also an honest review from Bulbfacts.com, please feel free to check it out and we appreciate your feedback on our products!
BulbFacts | Boslla Bullet 4-Mode LED Headlight Kit Review
You can upgrade the high beam or low beam bulbs to LED bulbs separately.
LEDs are light-emitting diodes that convert electrical energy directly into light energy, and xenon lamps are high-voltage electricity emitted through the discharge of xenon gas in the bulb.
HIDs emit a lot of heat and a large portion of their emissions fall in both the IR and UV spectrum.
Therefore, LED will be more energy-saving and environmentally friendly and have a longer lifespan than HID.
It is possible to upgrade your low beams to LED bulbs alone. If you live in the city, you will probably use your high beams less frequently. But if you drive a lot at night and on dark roads, we suggest you can upgrade both high beam and low beam to LED bulbs.
The appearance of the car will be significantly different and more technological after upgrading the headlights.
seltzernator
