LED replacement Lights
josh220
Banned
I want to replace my license plate lights, map light, dome light, all of the door lights, and also the rear cargo light. What sizes do I need for all of these on an 07?
I know that 168 fits the license plate lights, but on the LED sites, all of them are 168/194/etc on the same bulb. Is that still what I need for that?
The sylvania sizing page doesn't say what size bulbs I need for the doors. Thanks.
i am in the process of replacing them. got the package today and just replaced the rear dome light, one door light and one side running board. i bought mine from superbrightleds.com
the 194 i use high power WLED and the dome i use the high power 3022-WHP2
For the interior lights, do you just pop them with a flathead screwdriver? I ordered white for my license plate and map light, and blue for all 4 doors. I'll get some more white for my dome and rear when i find the ones that will fit.
i haven't change the map light and the dome light yet. only did the rear dome. yea, get a small flat head and pop them right out. same as the doors.
Alright thanks. I ordered these 6-led bulbs (3rd ones down) for my doors, map light, and license plate. Should fit even though they are slightly bigger than the 5-led's right?
yea, there's room inside so they should fit. mine's are the 4th one from bottom
here
and the domes are the 3022-WHP2 Festoon bulb , same page as yours
josh220 said:
how many of the 3022's do I need to order? One for. Each dome? Or 2 for each one?
one for the middle dome, one for the rear dome. 2 194s for map, 4 194s for doors and 2 194s for lic. plate. i just replaced all 10 mins ago and will put up pictures later tonight. they look pretty nice and bright compare to stock.
here are the pictures of the new led bulbs:
The PIAA bulbs I ordered for my low beams came today and they are bright as hell. I'm sure it's not as nice as your HID kit though. The LED's should be here Monday or Tuesday so then everything will be bright.
mine is not a hid kit tho... :D :D
it's actually a full tsx real hid projectors and oem 85122+ bulbs conversion.
All of my LED bulbs came in the mail today except for the 2 dome bulbs. It took me 5 or 10 minutes to install all 4 doors, 2 map lights, and the 2 license plate lights. I'll try taking some pictures tonight of how they look. (Not sure how well my iPhone takes pictures in the dark.)
