Team_Jake
Member
so it looks like TG sells the Verso housing by itself for build-your-own? Cool!
They used to, still pretty expensive to build a working unit.
so marlin crawler... is selling again or maybe first time ever?
3.4-liter 5VZ drivetrains (MC31) | Marlin Crawler, Inc.
Marlin and TG have been selling these 5VZ adapter plates for a while. I bought a used TG one not that long ago (was a good deal), but have been leaning more and more toward an atlas the more I think about it...
atlas you say?
so this allows the 3rd gen engine and trans to be used on other platforms. This really has zero benefits for 3rd gen owners. (other than maybe this opens some new possibilities for FAS?
and this is fine but we are still screwed because now everybody gets to use our platforms engines/trans on their trucks with their transfer cases....
so are there really any options beyond special build it yourself transfers?
unless somebody wanted to build the lefty again we are still SOL.
So it appears this has never manifested? I'm mostly out of the loop but still on the search for a Lefty tcase. Nothing ever shows up in the MN area used so I've been holding out hope for new stuff.
A few years ago I was set buying a lefty (see my posts on the first page), but if there’s anything I’ve learned in the last few years it is to not count on Marlin Crawler to meet their promises. I ended up getting a NWF Eco-Crawler VF2A/VF2A (which came out recently and is better in nearly every way).
Very nice just looked it up. Did you use your stock case behind that?
Another happy NWF Eco crawler user here.
You get a very easy to find donor case for the gears that go in the NWF case, and then you have to take yours completely apart (even more apart than the middle donor case) and install a new input shaft.
I got their triple stick kit as well. I have a manual trans and the doubler has been AWESOME on tougher obstacles. Both going up and down - you can just idle down big ledges and not even touch the brakes.
Any issues getting the transfer cases to seal completely?
Mine has a little oil on the outside after a year and a bit (and two long CO/UT road wheeling trips). I'm not entirely sure where it's coming from, it seems like the top somewhere. Maybe a little oil of of the breather or shifter housings? But it isn't really going through much oil.
I got everything shiny and clean and dry (used rubbing alcohol to remove all traces of oil from the mating surfaces) and then user Toyota FPIG when installing the rear section of the case onto the rear transfer case. And didn't have any issues with the big o-ring that seals the two halves of the NWF case together.
