anniesball72
Member
I have a LCE Dual comp clutch kit installed in my supercharged 5 speed swapped Runner.
Over time I have developed a problem (soreness and pain) with the bottom of my left foot due to operating my clutch pedal. Due to the area of the clutch pedal on my foot and the amount of force it takes to press it down.
The pressure plate that comes with the clutch disk is rated for 2100lbs of clamping force. This is much higher than stock.
At the time of the swap I wanted to get a Marlin but they weren't available at the time.
I have removed the return spring temporarily to see it if made a difference and it did not.
I was wondering if anyone knew of a smaller bore master cylinder I could use that would require less pedal effort????......
Thanks,
Thanks,
