The purpose of this thread is to let everyone know the lessons I learned from doing the front CV axles, seals and the tools I found to be most effective.
CV boot saga:
I started out with the premise that I can simply swap out the old boots with new OEM boots. However, I feel that the shafts on my vehicle are aftermarket because the boots did NOT fit. I bet OEM boot kit works well with OEM axles, as others have attested to. The outer boot fits PERFECTLY but the inner boot does not. Look at the pic below, see how the inner boot is not round and the grease is still oozing out?
Diff axle seals:
I bought a set of Timken seals and installed them. The FSM shows how far to install the driver side but I wasn't able to find any info for the pass side. My first attempt resulted in the seals leaking gear oil.
The driver side diff seal has to go in just flush with the outer. Here's a pic of where the seal lives. You need to tap it in squarely but first, put some grease on the back side of the seal where the spring is. This helps keep the seal from popping out while you're tap in the seal into the housing.
The passenger side seal is a different story since it lives in the axle tube. Take a close look at the picture and you can see how the axle tube is dirty for the first 1/4" or so, then it becomes shiny. The seal needs to sit in this shiny area, as close to outboard as possible.
Before I learned about the above points about the correct locations, I blamed the Timken seals themselves. I always use Timken seals and was beginning to doubt the seals so I purchased OEM seals from the local dealership. Well, you know what? The seals are IDENTICAL, right down to the par number etched on the seal themselves. Only the last digit is different!
The part number is BH53201 for OEM, BH5320F for Timken.
Conclusion: Timken and OEM seals are good for this application, just be sure to install it correctly!!
To be continue since I've reached my pic uploading capacity.
CV boot saga:
Diff axle seals:
